07-31-2023, 03:51 PM | #1 |
Quandary
I have the tail light housing for my 48 merc, one of the mounting studs is broken off. It's bad enough that the person I got it from started to drill it out, but it went off-center, he then tried to drill a small pilot hole in the center. The bit is approximately 1/32"or maybe smaller, the drill bit is broken off in the tiny hole. for a week I've been soaking it with B'laster and tried heating it with a torch using a small center punch to try to get it out, so far, no good. I'm afraid to heat it more as the area around the stud has started to melt. any ideas?
07-31-2023, 04:23 PM | #2 |
Re: Quandary
Drill & tap 4-32 next to it, and another opposite. Screw in a couple of screws the length of the missing stud, then build them up with JB Weld, file it down for your new stud. Without seeing it, that’s my best guess.
Alan |
07-31-2023, 04:54 PM | #3 |
Re: Quandary
Btw, the broken stud is a 1/4"-20 so there's not a lot of room to work with.
07-31-2023, 09:44 PM | #4 |
Re: Quandary
tom1948, check Ebay. Don't know which side you are working on but there was a NOS LH for $39.95.
08-01-2023, 02:36 AM | #5 |
Re: Quandary
