Old 07-28-2023, 08:51 PM   #1
old ugly
old ugly's Avatar
Default huckster question
1928.
i have the frame and driveline completed and about to start on the body. the necessary stock body parts are at the sandblaster rite now.
i have the plans from wagon works.
i am using the sedan front A pillar and windshield opening.
i have the front section of the subframe that goes from the A piller to just behind the front seat, from a sedan.
what are your thoughts on using that section of the stock subframe and making original style front floor boards or should i run a wooden floor rails all the way up to the A piller?
and if you have any pictures of that area if you used the ford subframe.
thank you
old ugly
my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want."
old ugly is offline   Reply With Quote
Old 07-28-2023, 09:27 PM   #2
Brentwood Bob
Default Re: huckster question
Your seats maybe a problem getting the right height if you eliminate the section of stock subframe. The space behind the seat is open into the bed on mine. I don't know what seat is in mine. Was your seat a bench type? Mine has a floor pan under the seat, and a subframe.
Mine is a 31 indented firewall so it's apples and oranges, I noticed you said 1928 so ignore me.
Brentwood Bob is offline   Reply With Quote
Old 07-28-2023, 09:33 PM   #3
old ugly
old ugly's Avatar
the car the subframe came out of had the folding bucket seats.
Brentwood Bob if you get a chance can you show me a picture of that area.
thank you.
old ugly
Old 07-28-2023, 09:39 PM   #4
Brentwood Bob
Maybe. See what I can do tomorrow.
Old 07-30-2023, 07:49 AM   #5
Russell Reay
Originally Posted by old ugly View Post
1928.
thank you
Here are pics of mine using Wagon Works plans. Per those plans, my 2 X 10 sitting on top of the frame rail goes all the way to the A pillar--no subframe. I do not have any original seats, nor the opportunity to 'test drive' another A, so I am making my own. The WW seat plans just don't appear to be that comfortable. These are from a Honda Civic, and I mocked them up using 2x4s for support until they felt comfortable. Now I am fabbing the steel supports. I have been building this car for about two years--learning a lot. Let me know if I can help
Russell Reay is offline   Reply With Quote
Old 07-30-2023, 01:46 PM   #6
Brentwood Bob
Russ, is that white oak?
Old 07-30-2023, 02:54 PM   #7
Russell Reay
The 2 x 10 , 2 x 4 cross members, and roof slats are red oak. The rest of the superstructure is white ash, and the bed floor is southern yellow pine flooring. For 40 years I have saved every tree big enough to saw, and had the guys at the local high school tech center saw them on their Woodmizer. I think I have enough ash left to make the doors. The 2x10 in the photo is grubby looking from so many months of using it as a work bench while leaning in to the car's center. This huckster continues to be a real learning exercise.
Old 07-30-2023, 03:23 PM   #8
Brentwood Bob
Should sand out. Spar varnish finish after stain?
Old 07-30-2023, 03:43 PM   #9
Russell Reay
Spar varnish, but no stain.
Old 08-01-2023, 10:31 PM   #10
old ugly
old ugly's Avatar
great pictures, that helps
thank you.
old ugly
