#1 |
Charlie made up this "retro" 4 BL carb, intake and fuel pump system for me to install on my 1947, 59AB. Carb is an old Rochester from the early 1950's, old Sharp 4 BL intake and an old "combo" fuel pump.
Hope to start the install soon. Updates to follow. VA ROOOOOOOOOMMMMMMMMmmmmmmmm! |
#2 | |
![]() Quote:
#3 |
That's the perfect carb for any flathead 4 Barrell intake I always have a few in stock for similar conversions.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587 |
#4 |
Been running one for 35 years on an Edmonds intake. I recently came to posses a 1957 283 'Power Pack" version. Much improved carb vs the 55 Buick I had. Thankfully the float bowel and lid are interchangeable.
Much improved accelerator pump, venturi boosters and secondary air valve. My motor (basically stock duel exhaust and Chev type distributer liked 1" of spacer between intake and carb. If your not a purist this would be the carb to use. |
#5 |
Looks great! Let us know how well it runs . . .
#6 | |
Gene, I'm a little fuzzy on these things, so could you clarify something for me? Are all of the carburetors you are referring to here Rochesters? I know some Chevrolets had Carter WCFB's and some Buicks had 4 BBL Strombergs, so I want to make sure I understand what you are referring to. |
#7 |
Yes Charlie and I are referencing the Rochester 4GC. They are the ugly sister to the 2GC's you like to run.
I was going to go with a WCFB but I got looking at them and they were pretty complicated. The Rochester is simple enough even I can work on it. How is life in Minnesota? . |
#8 | |
![]() Quote:
![]() Life in Minnesota is good, but we're sharing the heat wave like everyone else. I am 20 Miles north of Brainerd and it was 96 here yesterday and 94 today. Luckily, I have found out that if I am super careful about keeping the doors shut as much as possible on my shop, I can keep the temperature inside below 70 all summer. That helps a guy keep on top of his projects. ![]() |
#9 |
If anyone is intersted I have a rebuilt '53 Olds Rochester 4GC for sale in the early V8 swap meet section. Fully guaranteed. Rochester number 7005600.
Sal |
#10 |
While we’re talking these types of carbs....if I post a couple of pics of a set I have, can somebody have a go at identifying them...I know they’re Carters.....I think they’re a dual quad pair.....
Thanks.....Mark
I'm thinkin' about crankin' My ragged ol' truck up and haulin' myself into town. Billy Joe Shaver…RIP |
#11 |
This is the second.
#12 |
Flatford8, you may want to contact Jon Hardgrove at the Carburetor Shop in Eldon MS. He is very knowledgeable.
I dig coal, which provides motivation for EVs. |
#13 |
#14 |
Those carbs are WCFB CARTERS For two different Applications! Dave
#15 |
It's not real easy to tell without seeing the other side of the carbs and the throttle levers. The first one with the vacuum secondary diaphragm housing is either a '56 Mercury 312, or a '57 Lincoln 368. Could also be a mid 50's Chrysler Hemi that also used the Carter WCFB with vacuum secondaries.
The second picture is also a Carter WCFB and has no choke or drilling for the choke shaft. Pretty much has to be the secondary carb for a '56 through '61 Chevy 265 or 283 small block. Like I said, seeing the other side is a major clue. I assume the part number tags are missing. Sal |
#16 |
The one with the choke has “1273 cast into it and a triangle tag that says “59”, the other has “1310” and no tag. I have an Anderson 4bbl manifold that would need an adaptor to use these. I “assumed” they were a set because one had no choke and be used as a secondary.
#17 |
Thanks for your help!
#18 |
The carb wit the vacuum secondaries does not have the throttle lever like '56 Mercury or '57 Lincoln used. Best gues is mid 50's Chrysler hemi.
The carb with no choke does not have a Chevy style throttle lever, so I woud say maybe a secondary carb for Cadillac or a '57 392 Chrysler hemi. Both of thos cars also offered two four barrels in the 50's. the casting numbers don't really help solve it unless an expert on them. There was never a 2x4 setup that used both a mechanical secondary and a vacuum secondary carb is the same set. Sal |
#19 |
Thanks Sal!….. and my apologies to 47topless!…..it was not my intention to hijack his thread!… I know little about carbs and am trying to learn when I get a chance. The guy I got them from was a Hemi-guy so the Chrysler idea is probably correct…..again, Thank you !!!!
#20 | |
![]() Quote:
Also, I just replied to your PM. Sal |
