Old 07-20-2023, 10:22 PM   #1
California Charlie
California Charlie's Avatar
Default Slant Windshield Wooden Header Replacement
Hi All,
I'm going to replace all the top wood on my '31 Slant Windshield 4 Door and wondering, once all the old wood is removed, is there an easier way to install the wooden header without the metal cutting and re-welding of the window pillar sides.
Thanks in advance to all who reply to my question.
California Charlie is offline   Reply With Quote
Old 07-21-2023, 05:49 AM   #2
Oldbluoval
Oldbluoval's Avatar
Default Re: Slant Windshield Wooden Header Replacement
The header cover is welded in spots and has to come off
So, no.
Oldbluoval is offline   Reply With Quote
Old 07-24-2023, 09:06 PM   #3
Bick in New Zealand
Bick in New Zealand's Avatar
When I did the wood in the Victoria, a friend had done his header previously, and made them in two pieces, so that they could be fitted, after welding. It worked out really well. Of course Murray was just interested in getting them out the door, so you will find charred wood from the welding , during body construction. Hopefully Spider may chip in and add some further comments.
1928 Roadster (CA67)
1931 Deluxe Coupe RHD
1931 Victoria RHD
Model A's don't leak oil they just mark their territory.
Bick in New Zealand is offline   Reply With Quote
Old 07-24-2023, 09:59 PM   #4
California Charlie
Thank you.
I was just thinking that there must somehow be a better way to accomplish this without the metal cutting and welding.
Do you know if there are any repair manual chapters dedicted to this situation?
Old 07-26-2023, 04:08 AM   #5
Bick in New Zealand
Give Spider (Richard) https://www.fordbarn.com/forum/member.php?u=1954 a private message, I'm sure he will be able to give you some further information.
1931 Victoria RHD
Old 07-27-2023, 06:43 AM   #6
edzaha
The only cutting and rewelding is a very short section on each side of the metal header panel Cut carefully install the header, and when you go to weld put some steel behind the weld area to keep the heat from burning the wood. Weld in short bursts.
edzaha is offline   Reply With Quote
Old 07-27-2023, 12:35 PM   #7
Oldbluoval
Oldbluoval's Avatar
Edzaha- agreed 100%. I’d be skeptical of other posts urging header in pieces.
I would us some copper or brass behind the tack welds so it likely wouldn’t stick and leave the slug to get out
Old 07-28-2023, 02:38 PM   #8
Jerry in Shasta
Jerry in Shasta's Avatar
I had the same issue with my S/W I cut the welds with a thin Dermal cut off wheel. Before installing the wood I "tinned the area with a low temperature brass rod. I work the cut area metal to bring the gap ends close together. I then hit the tinned area with the torch for about two seconds. The tinned brass flowed across the cut. Yes.. the wood was discolored but not burned.
Connoisseur of Rust
Jerry in Shasta is offline   Reply With Quote
Old 08-02-2023, 06:11 PM   #9
California Charlie
Thanks to all that responded to my question.
I tried contacting Spider as suggested, but I did not get a reply back.
Does anyone have a picture, or pictures, showing exactly where those metal cuts arre made?
I don't want to cut more than is necessary.
I'm certain that I'm not the only one who has founf themselves in this situation,
Old 08-03-2023, 10:16 AM   #10
edzaha
You should be able to see where the spots are after you take all the nails out. They are on both sides of the metal header and are about half an inch long
Old 08-22-2023, 08:55 PM   #11
podiatristwood
Find a wooden header with ends that can be wrapped around the pillars to fill in the spaces. The width or inclusion of trim pieces in some cases allows for greater coverage. To cover the empty space between the pillars, use beautiful wooden trim pieces. There won't be any substantial adjustments needed.
geometry dash lite
podiatristwood is offline   Reply With Quote
