Old 07-20-2023, 04:16 PM   #1
Daveyjonez
Default Odyssey Battery w Generator
Hello All:
Posted this over on the HAMB too (got some good insight, just wanting to see if anyone here has ever actually run one)- has anybody used the Odyssey PC680 w a generator (12V)??
If so, any issues??
Thanks in Advance,
Dave
Daveyjonez is offline   Reply With Quote
Old 07-20-2023, 04:33 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Odyssey Battery w Generator
Originally Posted by Daveyjonez View Post
Hello All:
If so, any issues??
Thanks in Advance,
Dave
Old 07-20-2023, 04:52 PM   #3
Daveyjonez
Thanks Pete, that's the one I have- no charging issues from your experience??
Old 07-20-2023, 07:29 PM   #4
petehoovie
petehoovie's Avatar
Picture of battery....only...
Old 07-20-2023, 08:59 PM   #5
Daveyjonez
Ah- thank you!
Old 07-20-2023, 09:22 PM   #6
1948F-1Pickup
1948F-1Pickup's Avatar
I've got a PC1500 on the truck but it isn't a 12 generator, it's a 12 volt GM alternator.
1948F-1Pickup is offline   Reply With Quote
Old 07-22-2023, 09:30 AM   #7
rotorwrench
rotorwrench's Avatar
Used to have a 12/24 start cart for ground starting the helicopters. Originally it had four 6-volt batteries but we eventually changed it over to two 12-volt Odyssey batteries since they had the highest cold cranking amps we could get. They lasted a long time under mostly 24-volt use but they weren't cheap. Starting the little turbine shaft engines took a lot of amperage. We would have to charge it back up after each use.
