Old 07-18-2023, 01:58 PM   #1
larry harding
Default radiator ....speedster
working on my speedster i found that the solder was cracked where the tanks are fastened as well as some older repairs. i removed the tanks and found about half the tubes were stopped up, had a hell of a time clearing the tubes and damaged several tubes in the process. no worry i had another radiator a guy gave me. it felt heavy and when i tried to install the shell it wouldn't line up with the screw holes. the core is about 1/2 thicker than the regular a rad.
what is this rad from.? it looks right except for the thickness. new rad's are nearly $100.00. now. i'll be looking for a useable one. has anybody around western n.c. got a good one at a decent price???
larry harding is offline   Reply With Quote
Old 07-18-2023, 02:20 PM   #2
ronn
Default Re: radiator ....speedster
give a year Larry..............
Old 07-18-2023, 07:33 PM   #3
Synchro909
Synchro909's Avatar
I think the thicker core is a fairly reliable sign that the second radiator has an extra row of tubes in it. If so, it will cool much better than an original - experience speaking there. A speedster is light so it won't need as much cooling as a heavy car would. You could use a thermostat to keep it warm. IMO, if you can get the thicker one in, go for it.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 07-19-2023, 05:55 AM   #4
updraught
updraught's Avatar
$US450 on ebay. Bit short
https://i.ebayimg.com/images/g/js8AA...HQ/s-l1600.jpg
updraught is offline   Reply With Quote
Old 07-19-2023, 05:59 AM   #5
larry harding
the problem with the thicker rad. is the shell won't go on deep enough for the bolts to work. must not be an a rad even though it looks close. i had it mounted and hoses hooked up but could not put the shell on.
Old 07-19-2023, 06:38 AM   #6
marty in Ohio
marty in Ohio's Avatar
Larry, In your original post you said "new radiators are nearly $100.00 now." where on earth can you find a new radiator for $100.00?
Marty
marty in Ohio is offline   Reply With Quote
Old 07-19-2023, 08:49 AM   #7
midgetracer
midgetracer's Avatar
If it is a 30-31 it is a truck radiator. The shell on the truck is also about 1/2 inches thicker.
midgetracer is offline   Reply With Quote
Old 07-19-2023, 11:01 AM   #8
larry harding
oops!! i dropped a zero, what i meant was nearly $1,000.00
Old 07-20-2023, 08:24 AM   #9
ronn
you still havent given us a yr???????????????
details are important if you really want it to fit.
Old 07-26-2023, 11:06 AM   #10
larry harding
1930
