07-17-2023, 02:15 PM | #1 |
1928-34 AA or BB king pins wanted
Looking for a set or just drivers side kingpins. I have 2 right’s but no left pin.
Thanks
I know I can, I know I can http://www.flickr.com/photos/waltsprojects/ |
07-18-2023, 08:29 AM | #2 |
Re: 1928-34 AA or BB king pins wanted
32Dump,
Good Morning. I have a NOS Ford script set of 29-34 and V-8,(2) kingpins, (4)bushings, (2) U.S. Timken thrust ball bearings,felt and flat washers, all in a flattened, but legible original box. Plus a new KRW unused piloted reamer (KRW1.006 K6 AA38-4) marked but box lost. I also have (4) large orig pins (AA577) for the rear spring ends. Also in the package are (6) 1.00X3" bronze bushings for the ends of the rear springs. I sold a 29 AA before I finished the project. I have misc brake levers and splined links from AA's. The kingpin and reamer set and spring pin set all fit easily in a USPS medium 5x8x11 flat rate ("If it fits it ships"). The misc. are grimy but pretty unrusted and if you or someone comes for them are free. I want $150.00 for all, don't want to split it all up,plus probably $15 for the flat rate box. Call me -check your Private Messages on Ford Barn for phone and a good time to reach me. I'm in Brookfield Ct. north of Exit 7 on Rt 84. Russ Last edited by RDVAARK; 07-18-2023 at 08:51 AM. |
07-19-2023, 09:52 PM | #3 |
I’ve got a pair of nos king pins (no bushings) forsale $65 for the pair, you can still order new bushings from the suppliers
07-20-2023, 02:43 AM | #4 |
Sammy Guthrie at Arizona Model A has NOS 30/31 king pins and new thrust bearings in stock .
John in sunny morning West Drayton London . |
07-30-2023, 12:24 AM | #5 |
They were not expensive. Seller was Mohawk Vintage Automotive Last edited by Dodge; 07-30-2023 at 12:27 AM. Reason: adding information |
