Old 07-07-2023, 08:54 PM   #1
jhaase
Default Steering wheel repairs
I am considering repairing the cracks in the wheel of my 54 Crestline, anyone tackled this job lately & what are the best products to use?
Thank You
jhaase is offline   Reply With Quote
Old 07-07-2023, 09:38 PM   #2
Daves55Sedan
Daves55Sedan's Avatar
Default Re: Steering wheel repairs
Go to your favorite chain auto-parts store and look in the shelving for tubes of goop for modern car bumper crack repair. That liquid plastic in those tubes is about the closest match to the "bowling-ball" grade plastics moulded onto steering wheels of the '50's.
You will hear other people recommending JB-weld or bondo or some other stuff, and that can be made to look nice initially, the dissimilar materials expand and contract at different rates causing cracks all over again and the repair to fall out.
I don't remember the name of the stuff I used (bumper plastic repair), but it holds up real well and if you usually store your car in the garage, your repair will most likely last past your lifetime.
Lemme put it this way. I used this stuff for crack repairs on two '55 Ford steering wheels, both of which sat outside in blazing sun and freezing cold for decades and the repair has still held up well.
Daves55Sedan is offline   Reply With Quote
Old 07-07-2023, 09:44 PM   #3
Daves55Sedan
See this wheel in the picture. I repaired the numerous cracks around the top half the wheel and where the spokes meet the hub years ago and it still looks like this to this day. Picture was taken nearly 20 years after repair.
Old 07-07-2023, 09:47 PM   #4
Daves55Sedan
BTW, there are many other post on this site dealing with this type of crack repair offering good tips for tapering the cracked area using a Dremel tool and such.
Do a search located at top of web-page.
Old 07-07-2023, 09:58 PM   #5
mercman from oz
mercman from oz's Avatar
Repaired Steering Wheel by Daves55Sedan
Old 07-07-2023, 10:29 PM   #6
fordor41
fordor41's Avatar
I used JB weld & body filler on our '41 and was good 25 yrs later.nothing ever fell out or separated.
fordor41 is offline   Reply With Quote
Old 07-08-2023, 07:09 AM   #7
GLAmes
GLAmes's Avatar
I went the more expensive route.
https://www.eastwood.com/master-stee...w-instruc.html
'54 Skyliner. Restoration in progress.
GLAmes is offline   Reply With Quote
Old 07-09-2023, 05:55 PM   #8
jhaase
Thank You all!!
Old 07-10-2023, 08:35 PM   #9
jhaase
Today I found a new problem with my elec system, 54 Crestline,239, converted to 12 volt, all lights work correctly when turned on. When I step on the brake pedal the Right turn indicator on the dashboard lights up. I thought I had a bulb shorted across, so I removed all the turn & tail bulbs, same problem! I used my ohm meter to check all grounds, frame to body, body to block, block to frame, dash to frame, all OK!!!
Am I missing something?
Possible turn signal switch short??
Old 07-10-2023, 09:48 PM   #10
fordor41
fordor41's Avatar
sounds like in T/S sw. brake lights turn into turn signals so I'd start there. do all lights F & R turn on when you step on the brake or just the dash light?
Old 07-11-2023, 09:19 AM   #11
dmsfrr
dmsfrr's Avatar
The problem may be as simple as a couple accidentally swapped wires on the junction block for the turn signal switch. The turn indicator lights in the dash are normally connected to the wires for the front turn signal fixtures.
Attached is a turn signal wiring diagram for a '55 Bird, 'should' be 99% the same as what you have.
dmsfrr is offline   Reply With Quote
Old 07-11-2023, 01:40 PM   #12
jhaase
When stepping on brake pedal, R dash light, left rear brake light & R front turn light all come on!!
Old 07-11-2023, 02:57 PM   #13
paul2748
paul2748's Avatar
Did this start after new rewire or was everything ok and then it started doing it ? Are you using the factory junction blocks with new wires ?
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 07-11-2023, 03:11 PM   #14
Alaska Jim
Alaska Jim's Avatar
could be a bad ground causing the power to "backfeed" to the wrong bulb.
Alaska Jim is offline   Reply With Quote
Old 07-11-2023, 05:54 PM   #15
dmsfrr
dmsfrr's Avatar
The White/blue wire for the right front turn signal is plugged into a connector block terminal for one of the brake/rear turn signal circuits.
Most likely the Orange/blue wire terminal from the turn signal switch for the right rear brake/turn signal. Double check the two connections closest to the added yellow arrow in this diagram. That connector block will be very close to the steering column.
Old 07-11-2023, 08:20 PM   #16
jhaase
I got it solved, dmsfrr you were right, 2 wires switched, looking at the Ford wire schematic, from the turn switch to the front turn lights the wire color changes 3 times!! Hard to see color on 70 year old wires.
Thank You all!!
Old 07-12-2023, 10:32 AM   #17
dmsfrr
dmsfrr's Avatar
You're welcome.
I've got 70 yr old eyes, they don't help either.
Old 07-12-2023, 10:54 AM   #18
ventport
Another good product for fixing steering wheels is PC 7. Have done many wheels and they still look good.
ventport is offline   Reply With Quote
