Old 07-03-2023, 06:37 AM   #1
john charlton
john charlton's Avatar
Default 82 A 28/29 AA Truck cab question
When I bought this truck no body blocks were fitted . I fitted new blocks with the rubber pads tacked on . I was not sure if anything went under the front single bolt mounting so I fitted a rubber pad the same thickness as the others . This raises the front of the cab that the latches do not fit so I have removed them . At the front bolt the block is sandwiched between the steel channel so the connection will be " metal to metal" or is frame webbing involved ?
John in Suffolk County England . Mixed weather today sunshine and showers
john charlton is offline   Reply With Quote
