07-02-2023, 07:14 PM | #1 |
1940-41 pickup floor cab wood
Where are you guys getting to wood floor mounts for the ‘40 -‘41? I have what is left of the originals and they are tongue and groove. A lot of vendors sell them as separate pieces and I found a few that sell it as one piece tongue and groved. Which style is better?
Respecting and Resurrecting Ford Model A's. |
07-02-2023, 09:54 PM | #2 |
Re: 1940-41 pickup floor cab wood
Since my present build is not stock, I used the aftermarket steel ones but as is mostly ttt hot e case, the fit wasn’t the best. For my 32s I have used regular 3/4” ply with felt at the joints, primed tgg hot em, and painted them black top and bottom.
07-04-2023, 04:57 PM | #3 |
The ‘40 - ‘41 has a long running wood mount that sandwiches between the cab and frame. It is the length of the cab. I am not going to fan anything I was just curious who makes the best fitting wood for these cabs. Thanks.
07-05-2023, 11:45 AM | #4 |
The '38 and '39 blocks were finger jointed together into one piece. Some of the early '40's used the same 1 long piece block before Ford switched over to the multi blocks. Mack Products is a good source for truck parts. (Mack Products is not the same as Mack's)
https://mack-products.com/shop/produ...mounting-wood/ |
07-05-2023, 11:52 AM | #5 | |
With due respect, many 1938's use a floor framing similar (or identical) to the 1935-37. The top of the wood block is milled with the same pattern as the 1935-37 but with the tail added to support the bed ala 1939-41. |
07-05-2023, 12:08 PM | #6 |
07-05-2023, 01:17 PM | #7 |
Thanks for the replies. I appreciate it.
07-06-2023, 07:35 PM | #8 |
So my truck had one piece wood all the way down and is finger jointed. I found this pic of Northern Classic Trucks and it is the same, finger jointed. This company is no longer in business however. Also I don’t see anybody selling the rear section circled in red that the bed wood sits on. I want to buy all this at once and have it be right, and fit right.
07-07-2023, 09:30 AM | #9 | |
I was fortunate to have obtained mine through Northern Classics. Their kit was very nice but did require a little bit of fitment work.
07-07-2023, 10:07 AM | #10 |
Yes, Northern Classic Trucks was the only one I found that made the wood with the finger joints. I used their wood when I replaced the original cab wood in my 41 pickup. Like Mike I had to do some slight timing to get the correct fit but it was made from some quality wood.
07-07-2023, 10:45 AM | #11 |
I'm also missing that piece of wood. That kits you order for under the cab do not include it.
So if you find a source somewhere let me know. Kirk
1953 Ford F100 1950 Ford F47 (F1) 1940 Ford Pickup |
07-07-2023, 08:24 PM | #12 |
I was looking at the Midwest ford catalog and they sell two wood kits. One says replacement type, 6 pieces. The other says finger jointed, 6 pieces. Original style and includes the bed support. I am going to call them Monday and see if the original style is the same that Northern offered.
07-09-2023, 07:59 AM | #13 |
Several years ago I was able to snag an old original 1939 cab mounting blocks off Ebay after the PO found new reproduction. I used the original and traced out the pattern onto new cypress wood and with table saw and band saw cut/glued together. It fits like a glove to the frame. I think I still have the old original pieces somewhere if interested.
