06-24-2023, 10:54 PM | #1 |
Oil filter question - Kenz adapter
The Kenz oil filter adapter reportedly came with Motorcraft FL-1 filter. That filter is apparently no longer available, but FL-1A shows up. Does anyone know the difference between the FL-1 and the FL-1A, and will the FL-1A work on the Kenz adapter? Or a NAPA equivalent? Thanks.
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
06-24-2023, 11:14 PM | #2 |
Re: Oil filter question - Kenz adapter
The FL-1A works fine as do the other manufacturers equivalents. I like the Wix that is shorter than the FL's since I have a 90 degree adapter on the original purchased from Bill Kenz adapter I have. There threads about it on here somewhere...
Best regards, gb |
06-24-2023, 11:45 PM | #3 |
The FL-1A is the same size as FRAM PH8A or WIX 51515. Napa Gold 1515 is a WIX filter with the Napa name on it. Paint it with some Ford Engine Green paint before you install and it looks a lot better.
06-24-2023, 11:54 PM | #4 |
I also like the Wix 51515, same as Napa 1515, or Fram PH8A. There are many brands that will fit. Fram PH16 is shorter but will fit.
Edit: Same as Sam says, I was typing and didn't see his post.
Stickshift 1915 Model T touring 1931 Ford Model AA Flatbed |
06-25-2023, 12:18 AM | #5 |
Pennsoil - PZ-1 Fram - PH8A AC - PF2, PF20 Motocraft - FL-1A3 NAPA - 1515 Lee - LF-2 Tom Endy |
