05-29-2023, 03:20 PM | #1 |
1950 Ford Crestliner tune up question
Getting ready to tune up a friends 1950 Crestliner with the original flat head engine.
Can anyone advise a good spark plug replacement?? NGK?? What is the plug gap?? Point gap??? Thanks!!
Bob from Northport Northport, Michigan |
05-29-2023, 04:32 PM | #2 |
Re: 1950 Ford Crestliner tune up question
NGK: B-6L
Plug gap: .029 -.032 Point gap: .014 -.016 Dwell: 26 deg - 28 1/2 deg Initial timing of engine (dot on crank pulley): 2 deg BTC I normally set it at the first mark. The second mark is full advance Last edited by Merc Cruzer; 05-30-2023 at 10:03 AM. |
05-29-2023, 06:34 PM | #3 |
I personally like Champion H-10C plugs, typically in parts systems as 844.
I gap the points, don't worry about the dwell. Initial timing at dot on crank pulley. Runs well. |
05-29-2023, 11:03 PM | #4 |
Bob, x2 on what Merc recommends. I use a vac gauge as well when adjusting timing,
and carb adjustment. Also use a Sears tune up set, don't want to admit when I purchased it.
Henry Ford designed the flathead without the aid of a computer. |
05-30-2023, 12:50 AM | #5 |
My Autolite 216s work real well.
05-31-2023, 08:50 AM | #6 |
05-31-2023, 02:46 PM | #7 |
Ngk b6l
gb
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
05-31-2023, 03:39 PM | #8 | |
05-31-2023, 04:25 PM | #9 |
05-31-2023, 06:05 PM | #10 |
05-31-2023, 06:16 PM | #11 |
That mark was generated, when the engine rpm's were increased until it stopped advancing. It could probably be calculated in degrees, if I took time to measure it.
Not exactly scientific, but just an initially noted measurement for my engine. That was done before I had the distributor set on a Sun distributor machine, so it might be different now. |
05-31-2023, 06:33 PM | #12 |
The reason I asked is that the first modified flathead I had (in the early 90's) had consistent overheating problems. It was 276" merc with Offenhauser heads, a MAX-1 cam, a 390 Holley, and an MSD ignition system. I ran it in a '36 3-window for about five years until this, and the cramped nature of the car made me give in to the "offer I couldn't refuse" from a local guy.
I later learned that those MSD setups had SBC advance curves with 36 degrees total advance. Knowing what I now now, I'm sure I could have solved the overheating problem, and as a result would still have the car. Live and learn. |
05-31-2023, 07:08 PM | #13 |
When I rebuilt my engine, I used a new (different) block, fully tested, Over bored by .060, stock rods, new pistons, 1CM cam, stock 4" Mercury crank, a stock 1901 Holley, and EAC heads. I had the machine work done, but I disassembled and assembled it myself. I was trying to keep it as stock as possible, to match the rest of the car. No issues with over heating, which is remarkable considering when I come from a show in Denver back home I climb 3,000 feet (5,280 to 8,300) in 13 miles. After I had the distributor set on the Sun machine, it tends to run a bit cold, and slow to warm up. So I think I will keep her, since it is the first and last flat head I will probably ever rebuild. I got lucky, so I don't want to push it!
05-31-2023, 10:31 PM | #14 | |
