#1 |
OBH(?) 1933 carb
#2 |
Excuse my ignorance but can you define "OBH"? IF you are adhearing to "Original" as built standards for 1933, Detroit Lubricator is the carburetor you are referring to???
#3 |
WHY in heck do you find it necessary to continue making posts that make no sense to anyone besides yourself? All of our REGULAR participants seem to speak good-enough English that they should be able to figure-out and understand reasonably intelligent and qualified questions asked in a normal, explanatory manner. But what do I know? Coop . |
#4 |
deleted
#5 |
I you're talking about needing help with a Detroit Lubricator carburetor, Charlie Schwendler is the only person I know that will touch one of those abortions.
Sal |
#6 |
OBH = Office of Behavioral Health?? One Big Happy?? Online Booking Hotel?? Old Buckenham Hall??
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 05-26-2023 at 11:05 PM. |
#7 | |
'OBH' is on this '33 ford carburetor. Is OBH familiar to anyone? If so, what does it represent? Also, this carburetor has 'Lincoln 12V Zepher'. Now, is anyone familiar with that, other than being on a 'Lincoln 12V Zepher' carburetor? What is the significance of 'Lincoln 12V Zepher' on a carburetor? No mystery there. Obviously the past 87 years, the '33 Lubricator has been removed; replaced with this 'Lincoln 12V Zepher' I am not apologizing for a simple question. *** Last edited by highbeams; 05-24-2023 at 02:44 PM. Reason: clarity. |
#8 |
That is not a Detroit Lubricator, nor is it for a ‘33 car. It is a Holley built carburetor for a Lincoln Zephyr V12.
They are harder to come by than the V8 carbs, stands to reason. Later versions had a 4 bolt base, earlier, I think til 41-42, had 3 bolt base. Other than the script, 2 other differences, one being the Venturi size, two being the reverse throttle arm. Not uncommon to see a V8 throttle arm on a LZ carb.
I dig coal, which provides motivation for EVs. Last edited by 1952henry; 05-24-2023 at 02:57 PM. |
#9 | |
1942-1948 Lincoln Zephyr V-12 Model 06H ![]() See > https://www.ebay.com/itm/334691983224 Last edited by petehoovie; 05-24-2023 at 03:13 PM. |
#10 | |
#11 |
highbeams, nobody asked you to apologize, but just a question mark isn't a question in itself. What we can tell you about your carb is yes, it was originally on a Lincoln V12, and no, it is not a Ford Holley model 94. The venturi is 1 1/16", a little larger than the model 94, which has a venturi of .94". It should work just fine on any Ford V8.
Alan |
#12 |
A pic would have been worth a thousand words. It would appear you have a two barrel manifold {unknown Ford v8}and a Lincoln carb. If you want to make the engine run right, get a good Stromberg 97 and put on it.
#13 |
#14 |
Does your OBH carburetor have a two bolt flange or a three bolt Flange. If it is a 3 bolt, then your intake is not a 33. If it is two bolt flange and your intake has a two bolt flange, then have Charlie rebuild the carb. If you need / want a original 33 Detroit Lubricator carburetor, I have one for sale for $50.00. All the linkage is correct. Like all old carbs, it should be rebuild. I also have a nice 33 intake for $100.00. If you are interested, click on my 35 Roadster picture and send me a private message or an email.
I've got the old car disease. Thankfully there's no cure! |
#15 | |
#16 | |
He said the manifold is not a back-then Ford product; advised me to have the Detroit Lubricator 'rebuilt' when I receive it, simply because it's old. Do you know of a reputable rebuilder? Thanks, rockfla! Welll, a good tip on '34 manifold and a Stromberg 97 is my best bet. Last edited by highbeams; 05-24-2023 at 06:30 PM. Reason: clarity |
#17 |
Highbeams: If you're looking for solid drivability, I would not be running a Detroit Lubricator (unless total originality is your goal).
I would have the Detroit Lubricator rebuilt and then I'd store it and the original 33 manifold away. Then I would find a 1934 manifold and put a new Stromberg 97 carb on the car. It will run a LOT better, have more horsepower and be a much better driving car with the Stromberg 97. |
#18 |
#19 | |
Thank you for the big tip! What is available regarding Stromberg 97? and where? |
#20 | |
I appreciate the offer. Pat |
