#1 |
What is the maximum ID a wide 5 drum can be turned before needing replaced?
#2 |
12.060"
#3 |
There is no published diameter or specification from Ford.
#4 |
![]() ......... yet based on the premise that we have always deemed 12.060" to be the recognized safe - and LEGAL limit - for the '40-'48 drums, I can't imagine why we would assume that the similarly-constructed '36-'39 drums would fall under a different specification. Coop . |
#5 |
If 12.060 is max to turn the drums; what diameter is the wear limit?
#6 |
#7 |
Some say 12.090", but again not based on Ford documentation.
#8 |
Wonder what the deciding factor was in olden times; must be a reason that I find so many brake shoes with shims behind the linings.
#9 |
the maximum diameter depends on what state you are in .many different rules, i
#10 |
maximum dia depends on arc of the brake shoes, so say old line ford mechanics
#11 |
At one time a thicker brake material was available for your shoes. I believe discontinued now. 12.060 is some what standard and hard to find. Newc
