Old 05-05-2023, 08:54 AM   #1
Kenjt
Kenjt's Avatar
Default device to jump start my model A
Is there any kind of device that I can carry in my model A to jump start if the battery does not have enough power? In other words, if I go out for a drive, park the car, turn off the engine and then have a problem restarting the car.
Kenjt is offline   Reply With Quote
Old 05-05-2023, 09:00 AM   #2
Badpuppy
Default Re: device to jump start my model A
Crank.
Badpuppy is offline   Reply With Quote
Old 05-05-2023, 09:02 AM   #3
WHN
Make sure there are two of you. One to drive and one to push.
It’s really easy to push start the Old Ford. Just needs a couple of feet of movement. Or a slight decline.
Enjoy.
WHN is offline   Reply With Quote
Old 05-05-2023, 09:23 AM   #4
Ed in Maine
I would be very careful trying to jump start a Model A. It is possible to shear a rear axle key which in turn damages the axle key slot in the axle shaft. This is a very nasty and expensive repair.
I recently could not start my Victoria and wanted to move the car from the street to the garage. I did not have a spare coil which turned out to be the problem. If you remove the spark plugs, you can very easily use the starter to drive the car a short distance.
My engine has only about 2500 miles on it and has excellent compression. I know I have weak arms and I could not move the engine with the crank. Ed
Ed in Maine is offline   Reply With Quote
Old 05-05-2023, 09:26 AM   #5
LeonardS
Jump starting would have nothing to do with damaging an axle key. Push starting might.
LeonardS is offline   Reply With Quote
Old 05-05-2023, 10:34 AM   #6
1931 flamingo
1931 flamingo's Avatar
Try on-line for a "jump box. If you only find one for 12V it will work if no lights on. I've jumped my old A with 12V, no problem.
Paul in CT
Old 05-05-2023, 10:52 AM   #7
Merc Cruzer
Merc Cruzer's Avatar
Always park on a hill.
Merc Cruzer is offline   Reply With Quote
Old 05-05-2023, 11:41 AM   #8
rotorwrench
rotorwrench's Avatar
Most of the reliable units are both chargers and jump start set ups and they are really too big to haul around. They would likely have to be plugged in to a power outlet to function. It would be easier to carry a battery like the sealed valve regulated Optima types.
There are a lot of small six volt sealed batteries that are used for alarms and back up batteries that might be made to function if connected in parallel to increase the amperage output. It may cost as much as an optima to do all that and get the same amp hour capability. For a short run, a car could be started with a 12-volt battery but using a smaller 6-volt battery to run the coil in order to get to a place to purchase a new battery.
I wouldn't go on a long tour with a 6-volt car unless I knew the battery was up to the task.
Old 05-05-2023, 11:45 AM   #9
Curtis in MA
Check out Megawise jump start. They are 12V but as noted they will work.
Curtis in MA is offline   Reply With Quote
Old 05-05-2023, 11:53 AM   #10
nkaminar
nkaminar's Avatar
You can connect jumper cables at the starter switch and any convenient ground.
Old 05-05-2023, 11:57 AM   #11
Lanny
Lanny's Avatar
Do a search for topdon jump starters, they make many differnt
priced models and are light weight and small. They work very good.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
Old 05-05-2023, 12:01 PM   #12
harryc
there are many small portable devices. I have carried one for several years and used it once. check amazon
harryc is offline   Reply With Quote
Old 05-05-2023, 01:40 PM   #13
Charlie Stephens
Fix the real problem and then learn how to use the crank as a backup (which you should never need).
Charlie Stephens
Old 05-05-2023, 02:08 PM   #14
Curtis in MA
Charlie Stephens
I am the problem!
Old 05-05-2023, 03:02 PM   #15
Big hammer
52 years ago I parked my A in the driveway on a hill facing uphill, tried to start it in reverse but failed. Putting my back against the spare pushed it up and out of the driveway let it roll down the street and popped started it. That kid really wanted to drive his A, must have been to see a girl !
get a bigger hammer tap done
Old 05-05-2023, 03:58 PM   #16
fried okra
Location: Daniel Island,SouthCarolina/Knoxville, Tennessee/Sanibel Island,Florida
I've had one of basic Harbor Freight jump starters for 3-4 years, been OK so far.
https://www.harborfreight.com/automo...-starters.html
fried okra is offline   Reply With Quote
Old 05-05-2023, 06:44 PM   #17
J Franklin
J Franklin's Avatar
A model A starts easy with a hand crank. it would be very worth your time to learn how. Why own a vintage car and not know how to use it?
Old 05-06-2023, 07:16 AM   #18
denis4x4
denis4x4's Avatar
I have these handy dandy remote lugs on the hot rod and the '29 CCPU. Makes it easy to jump or charge. Available from Speedway Motors
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 05-06-2023, 07:25 AM   #19
ronn
I agree with rotor- carry a spare battery.
Old 05-06-2023, 11:42 AM   #20
Dan McEachern
https://us.gooloo.com/?utm_source=gg...SAAEgLj8PD_BwE
Dan McEachern is offline   Reply With Quote
