04-28-2023, 11:48 PM | #1 |
cruisomatic
So our 2 speed Fordomatic is toast and I found a '57 3 speed complete. I see they sell the newer style flexplate to replace the riveted type. My question is, instead of buying a new flexplate IF the one I'm getting is the riveted style, can't I just redrill our F/M/2 flexplate (3 bolt converter) to match the 3 speed converter which it appears is a 4 bolt converter?
04-29-2023, 05:04 AM | #2 |
Re: cruisomatic
If you found a 57 FM takeout complete, you would use the flex-plate that hopefully comes with it, whether early riveted (if in good shape) or the later service replacement style.
Where you are going to hit a snag (IMO) is with the TV LINKAGE(s).
- WANNA SEE A GOOD CAR WRECK? - https://www.youtube.com/watch?v=5oO226PgSkg KULTULZ - HAS MOVED ON TO THE HAPPY PROVING GROUNDS |
04-29-2023, 06:03 PM | #3 |
Re: cruisomatic
You have had no luck with finding a F/M/2?
Your main case is broken, correct? Have you considered finding a takeout with the correct case to rebuild yours? The 292 F/M/2 was used to the 1962 model year. 1961 saw the intro of the vacuum modulator valve, so if you found one of those it would eliminate the linkages.
- WANNA SEE A GOOD CAR WRECK? - https://www.youtube.com/watch?v=5oO226PgSkg KULTULZ - HAS MOVED ON TO THE HAPPY PROVING GROUNDS Last edited by KULTULZ; 04-29-2023 at 06:15 PM. Reason: THE USUAL REASON |
04-29-2023, 10:35 PM | #4 | |
Re: cruisomatic
04-30-2023, 02:12 PM | #5 |
Re: cruisomatic
That year model is needing the 2-speed replacement? Does it have a TV control mounted on the back of the engine? You mention Cruise-O-Matic but they were dual range units that started showing up in 1958. Single range FOMs were still in use up into 1959. After that they were all either 2-speeds or Cruise-O-Matics. Most later COMs were MX types with the medium case but there were small case versions too. Thunderbirds and Mercury cars used the medium case FOM & MOM in 57. Regular fords with light duty applications used the FX small case FOM. Fords with more horsepower may have a MX FOM but it depends on car weight and engine size. Big cars used the large case transmissions in both single and dual range but they had large engines too.
04-30-2023, 10:15 PM | #6 | |
Re: cruisomatic
04-30-2023, 10:25 PM | #7 | |
Re: cruisomatic
05-01-2023, 01:49 AM | #8 | |
Re: cruisomatic
Can you give me the TRANS ID STAMPING as found in the below ILL? Now the 1957 F/M ring gear was on the TC cover and the 1960 F/M/2 was on the flex-plate, right? If you are fed up with it, just ignore this post.
05-01-2023, 05:21 PM | #9 |
Re: cruisomatic
to answer your first queston dont try to drill your 2 speed flywheel.theres nothing wrong with the riveted flex plate used them and never had a problem.once in a blue moon one will fail but everything does sooner or later.if you get the 57 make sure you get all the linkage
05-01-2023, 05:37 PM | #10 |
Re: cruisomatic
If your proposed replacement transmission has the riveted brackets in the heavy flexplate and has a two-piece converter housing whereby the ring-gear is welded to the front cover of the converter, it is an air-cooled type converter and those were discontinued after the '56 model year in V8 cars, but still used in 6-cyl cars up into the early '60's.
So, who told you it was a '57 transmission? The air cooled converters required a '56 and earlier bellhousing that had the air intake and exhaust ducts. You would also notice that these FOM's have plugs in the cast-iron case where you would normally run transmission fluid lines to the radiator for cooling. In '54. '55 & 56, that cooler was located in the bottom radiator tank. |
05-01-2023, 10:20 PM | #11 |
Re: cruisomatic
05-01-2023, 10:21 PM | #12 | |
Re: cruisomatic
