Old 04-23-2023, 01:08 PM   #1
aandkt
Default 1936 Steering Box Lubricant
What lubricant works besst in my 1936 Ford steering box?
Thanks
aandkt is offline   Reply With Quote
Old 04-23-2023, 01:22 PM   #2
Kube
Super Moderator
Kube's Avatar
Default Re: 1936 Steering Box Lubricant
In my opinion, John Deere corn head grease. About $7 a tube.
Old 04-23-2023, 02:05 PM   #3
aandkt
Thanks
How many tubes does it take to fillan empty Box?
Old 04-23-2023, 02:07 PM   #4
Krylon32
Another vote for JD corn head grease. My memory isn't very good but I think I used 1 tube when I filled the 37 Hudson box in my 32 pickup.
Krylon32 is offline   Reply With Quote
Old 04-24-2023, 07:39 AM   #5
Terry,OH
Terry,OH's Avatar
You need a liquid that will get past the sector and into the two bearings. My suggestion is 140W Gear oil.
Old 04-24-2023, 09:03 AM   #6
JM 35 Sedan
JM 35 Sedan's Avatar
....and yet another vote for John Deere Corn Head Grease. I've used it in my '35 steering boxes and universal joints for the last 10 years. Has worked very well in both areas.
Corn Head Grease is a high quality multi-purpose, semi-fluid type grease available in an NLGI #0 grade. Although primarily applied in corn head lubrication, this product can be recommended for many applications in agriculture, automotive, construction and industrial environments.
Check out this YouTube Video below:
https://youtu.be/7zNhli-J0Gk
John
Last edited by JM 35 Sedan; 04-28-2023 at 09:43 PM. Reason: Added YouTube Video on JDCH Grease
Old 04-24-2023, 12:45 PM   #7
gwistrup
How do you get the corn head grease in the steering box? Will it pour or do you have to use a grease gun?
gwistrup is offline   Reply With Quote
Old 04-24-2023, 02:21 PM   #8
Krylon32
I used a grease gun with the tip removed from the pipe.
Old 04-24-2023, 02:45 PM   #9
Kube
Super Moderator
Kube's Avatar
I had installed a grease fitting to an extra filler cap. Install that modified cap, pack the steering gear box and replace with the stock cap. That way, I know the box is full.
Old 04-27-2023, 11:39 PM   #10
aandkt
Thanks Again
Old 04-28-2023, 10:41 AM   #11
F1 MIKE
F1 MIKE's Avatar
IF it leaks fix it use 140 gear oil.
F1 MIKE is offline   Reply With Quote
Old 04-28-2023, 12:03 PM   #12
evintho
evintho's Avatar
Cool Re: 1936 Steering Box Lubricant
I removed the box and shoved the cornhead grease in by hand. One tube did it.
https://www.fordbarn.com/forum/attac...1&d=1682701386
evintho is offline   Reply With Quote
Old 04-28-2023, 12:18 PM   #13
Seth Swoboda
Seth Swoboda's Avatar
John Deere corn head grease is "00" grease. If you can't find Deere brand most lubricant companies sell "00" grease.
Seth Swoboda is offline   Reply With Quote
Old 04-28-2023, 12:20 PM   #14
petehoovie
petehoovie's Avatar
Old 04-28-2023, 12:51 PM   #15
Steve in Denver
Steve in Denver's Avatar
Problem with JD Corn Grease, is, it will settle, even though it gets hot from the manifold, nd does not lube the top bearing, which will thus wear out.
Steve in Denver
Steve in Denver is offline   Reply With Quote
Old 04-28-2023, 02:29 PM   #16
1952henry
1952henry's Avatar
Actually, corn head grease, whether in a green tube or any other color tube is “0”. Cotton picker spindle grease is “00”, a pourable grease.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 04-28-2023, 05:44 PM   #17
Kube
Super Moderator
Kube's Avatar
Really? I'd better run out and check my farming equipment right now.
Old 04-28-2023, 09:30 PM   #18
JM 35 Sedan
Steve in Denver, Have you personally experienced this top bearing failure in the steering box of your early Ford V-8 when using JD Corn Head Grease?
John
Old 04-29-2023, 06:39 AM   #19
GB SISSON
GB SISSON's Avatar
Cap with the zerk seems like the best way to go. Simple and cheap and the top bearing can't escape the rising cornhead tide.
Old 04-29-2023, 11:53 AM   #20
Seth Swoboda
Thanks for the correction. A quick inernet search shows the 00 as a pourable type.
