#1 |
Bolt in, or what parts are needed?
-Thanks |
#2 |
Mine has a 39 trans and Mitchell OD. Pretty sure you just need the adapter kit since the later car was still a closed driveline, https://www.clingsaftermarket.com/ad....asp?prod=3000
#3 |
It would be easier to get a Mitchel synchronized transmission since it uses a model A type case. They aren't cheap though.
#4 |
#5 |
8 months would put you in December/January. Not a bad time to be working on the car.
But for the 39 trans, I have installed one before using a Clings adapter. Pretty straight forward. I recommend it although, If you have to buy one then rebuild and also buy the Clings kit, it can get pricey. It’s optional to lighten the flywheel/V8 clutch, but while it’s apart it makes sense. More $$ though. |
#6 |
Excuse my ignorance. What are the advantages of a 39 transmission? Thanks
Regards Chris Cape Town 28 Model A RPU, 29 Chevy Phaeton, 67 E Type FHC, 67 250SL Pagoda, 83 911 SC |
#7 | |
![]() Quote:
You can see the whole story at VanPelt's website. They specialize in the flathead V8's and the transmissions. |
#8 |
I recently bought three '36-'39 transmissions in various states of disrepair for $50 total. I think between the three I'll have the parts to make one good one. I also bought Van Pelt's book. I think it's a fun DIY project, I'm looking forward to putting some time into it over the winter.
#9 |
Tks GeneBob.
#10 |
The use of the term "39" is kind of a misnomer but it is the first year of the improved synchronizer system that included blocker rings. 1939 was the last year for top shift transmissions in cars so the 1940 passenger units are remote shift types with side mounted levers even though they have the same guts as the 91A type. The remote shift types are more common since they were used through 1948. The top shift design was only used in commercial pickups after 1939 but it stayed in service with few changes through 1952 in light duty pickup applications. From 42 on, all the top shifters were open drive so they have different mainshafts.
The 1937 and up 78 series top shift case can easily be set up with the later guts and a few parts are the same or usable. The double detent shift tower is also prefered but the 2nd/high 91A shift fork has to be used. The transmissions can easily be changed for either closed drive or open drive applications since the parts are all bolt ons. Side shift guts will fit in any top shift case but the 78 case or later is prefered Last edited by rotorwrench; 04-18-2023 at 01:07 PM. |
#11 |
There's a bunch of good info in this thread. I'm working on a '29, and i keep getting 'upgrade' suggestions without any explanation of what's involved.
To the original poster, i'd be very interested if you created a thread about the swap. |
#12 |
Looks like a simple parts swap. The T5 swap is much more involved.
#13 |
The cup that bolts to the rear of the trans has a different bolt pattern, 6 vs. 4. The best way is to get a V8 piece. When I did my wide-bed years ago, I drilled the A piece in 4 places. This worked but required making 7/16's nuts out or 3/8s because of the difference in OD of the rear piece. All else is bolt-in with Clings adapter.
#14 | |
![]() Quote:
Take pics and talk to them. See if you can drive the car or at least ride and watch it driven. The advantages are several. Greatly improved driving pleasure is probably at the top. Gears 2 and 3 are synchro. THE INTERNAL GEAR SETS CAN BE CHANGED FOR DIFFERENT DRIVING APPLICATIONS. (A very popular combination is the 26 tooth gear set and a stock 3.78 rear end) The whole unit is stronger and will last longer. Slightly better gas mileage due to better ratios in the lower gears. The 39 and later have helical gears so they are quieter. |
