Old 04-12-2023, 11:30 PM   #1
JD
Default 1934 pickup instrument light bracket
I have an instrument light bracket for my 1934 pickup I have cleaned and painted but I can't see where it mounts. Can anyone advise please?
JD is offline   Reply With Quote
Old 04-13-2023, 12:45 AM   #2
deuce lover
deuce lover's Avatar
Default Re: 1934 pickup instrument light bracket
Mounts on the cowl of the body in the middle in alignment of the instruments.
deuce lover is offline   Reply With Quote
Old 04-13-2023, 02:39 AM   #3
petehoovie
petehoovie's Avatar
Old 04-13-2023, 07:13 PM   #4
JD
Thank-you. Should I be looking on the firewall, as opposed to the cowl?
Old 04-14-2023, 12:05 AM   #5
deuce lover
No .It needs to be closer to the gauges as it lights them up. Where the dash attaches to the cowl in the body.Look there.
Old 04-14-2023, 07:45 PM   #6
totto
totto's Avatar
Duce Lover is correct, the "center " screw of the dash board is where I attached mine and the switch is on the driver's side (bottom portion of the dash. You will see "3 " holes: two outer for attaching switch and the "large" center hole is where the "toggle" switch sticks out.
totto is offline   Reply With Quote
Old 08-11-2023, 03:35 AM   #7
JD
Thanks for the helpful advice - I was able to locate the correct position. And sorry, I thought I had replied to acknowledge this ages ago.
