#1 |
Does anyone have pictures of how the cowl lacing goes at the bottom of the cowl sides? Does it end at the clips or go to the bottom of the cowl? Does the lacing stop at each side of the rear hood hinge bracket? I would like to see pictures of the cowl lacing installed and the radiator lacing installed The upper door glass seals are they glued to the top of the inside of the door caps? Does the transmission to floor rubber sponge seal go on top of the transmission cover plate then is covered by the floor mat? Or underneath the transmission cover plate? Any photos of these would be appreciated Thank you |
