Old 03-28-2023, 03:46 PM   #1
flathead34
flathead34's Avatar
Default 1934 Brake Drum Measurement
What is the maximum ID measurement for a 1934 brake drum?
flathead34 is offline   Reply With Quote
Old 03-28-2023, 03:55 PM   #2
Brian
Brian's Avatar
Default Re: 1934 Brake Drum Measurement
12.060"
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 03-28-2023, 04:21 PM   #3
34fordy
34fordy's Avatar
Originally Posted by Brian View Post
12.060"
With absolute respect Brian! Where have you found that spec in any Ford literature? I saw a post somewhere that said to the contrary. I am sure there have been many thousands and perhaps millions turned far past .060. Whether safe or not, and no new drums available, folks will probably take chances. Possibly not as critical for the mechanical brake cars I would think. IMHO.
34fordy is offline   Reply With Quote
Old 03-28-2023, 05:05 PM   #4
DavidG
DavidG's Avatar
12.060" is the Ford Service Bulletin recommendation. Recalling that was printed when you could still buy new ones for a song from Ford, modern experience suggests that 12.090" is the outer limit.
Old 03-28-2023, 05:38 PM   #5
Kube
Kube's Avatar
Yep, and oversize brake shoes used to readily available. Of course, after a number of folks were hurt because of them, and the lawyers got involved, well, no more oversize shoes.
Just because "there have been thousands and perhaps millions..." doesn't make it smart or safe.
Me? I prefer to do things correctly.
12.060" is the Ford spec.
Old 03-28-2023, 06:22 PM   #6
Newc
Newc's Avatar
Legal businesses will stop at 12.060" After that you're on your own. Newc
Old 03-28-2023, 06:32 PM   #7
34fordy
34fordy's Avatar
Any chance you could post a picture of that bulletin David? Then we could finally put this to bed. I do believe that Kube is absolutely right on better safe than sorry. When the high cost of new parts is extremely high for some of us folks we take the low road and do things we should not do!
Old 03-28-2023, 07:22 PM   #8
fordyford
fordyford's Avatar
When Colorado still had the annual safety inspection windshield sticker program (many years ago) the rule for machining any brake drum was .060" oversize then it could wear out to .090"
fordyford is offline   Reply With Quote
Old 03-28-2023, 09:42 PM   #9
DavidG
DavidG's Avatar
Sorry, I'm away from my car stuff until next month. Make no mistake, I am not suggesting that the drums be turned past .060.
