#1 |
it appears my new rings are a little to sloppy(0.006) in my stock pistons (3.6274) Summit doesn't have any - rock auto nothing , does any one have a 1-800 number for China lol
#2 |
Check with John Mummert - all things Y block
#3 |
Might be able to supply you with N.O.S. *** U.S.A. made *** parts ---
Always best to simply call me --- 516 - 485 - 1935 --- New York.... Craig .... |
#4 |
thx craig
i don't need NOS if you come across something cheaper for 272 standard bore let me know see you at spring Carlisle |
#5 |
Lawrence,
There is N O Chineseum, so your only options are N.O.S., of which you notice I have the best price in the Universe ---- and having them custom made / re - molded, which will run you triple to quadruple the price I quoted you...... Well --- you can always turn that block into a boat anchor...... |
#6 |
have a look at these at Summit Racing Silv-O-Lite Cast Pistons https://www.summitracing.com/parts/u...-std/make/ford I did not look for oversized.
Allen '55 F100 with slightly newer 292 Y-block find the detailed project story at https://www.ford-trucks.com/forums/1...o-project.html Last edited by AllenV; 04-07-2023 at 11:57 AM. |
#7 |
EDIT 7APR2023-DOES NOT FIT THE 272, CHECK COMPRESSION HEIGHT
And here they are as 0.040" oversize https://www.summitracing.com/parts/u...-040/make/ford Summit Racing part number UEM-3186-040
Allen '55 F100 with slightly newer 292 Y-block find the detailed project story at https://www.ford-trucks.com/forums/1...o-project.html Last edited by AllenV; 04-07-2023 at 11:56 AM. |
#8 |
those 40-over pistons are 3.665 in. bore. I was thinking that if you need a bit larger maybe a standard 292 piston would fit. BUT NO. The 272 has a 1.857" compression height where the 292 is 1.760".
EDIT- WRONG, 1.857 height is for the 256 motor, see my next post below.
Allen '55 F100 with slightly newer 292 Y-block find the detailed project story at https://www.ford-trucks.com/forums/1...o-project.html Last edited by AllenV; 04-07-2023 at 11:59 AM. |
#9 |
I already beat that price hands down, but cvicky / Lawrence is hoping to find some on somebody's
" Dollar table " ....... and, as we know, Gooooooooooood Luuuuuuuuuuuck on that ....... |
#10 | |
![]() Quote:
- WANNA SEE A GOOD CAR WRECK? - https://www.youtube.com/watch?v=5oO226PgSkg KULTULZ - HAS MOVED ON TO THE HAPPY PROVING GROUNDS |
#11 | |
![]() Quote:
How can the compression height be that much different ? Sal |
#12 | |
![]() Quote:
That 3.62 bore and 1.86 compression height belong to a 256 motor. The summit pistons I inked above DO NOT FIT A 272 FYI another oddball compression height is a 292 HD Truck motor All this info is thanks to Mummert at http://www.ford-y-block.com/dimensions.htm
Allen '55 F100 with slightly newer 292 Y-block find the detailed project story at https://www.ford-trucks.com/forums/1...o-project.html |
#13 | |
![]() Quote:
Thanks for the explanation. Sal |
