03-26-2023, 03:52 PM | #1 |
A smoother ride
I carry 120 lbs of concrete in the bed of my 1930 pickup truck. It makes the ride better. Any one else tried this?
thanks : Dean |
03-26-2023, 04:31 PM | #2 |
Re: A smoother ride
A VERY well know phenomenon. The ratio of sprung and unsprung weights is changed in favour of a softer ride.
03-26-2023, 06:45 PM | #3 |
Re: A smoother ride
Shocks are good.
03-26-2023, 06:51 PM | #4 |
Re: A smoother ride
I have 150 pounds of coal in the trunk of my 30 coupe. Didn't notice much change.
03-26-2023, 07:00 PM | #5 |
Re: A smoother ride
300 lbs of cement on each running board works too, don’t even have to lift them, i pull up to the trough and cut the top off the bag.
03-26-2023, 07:15 PM | #6 |
Re: A smoother ride
03-26-2023, 07:19 PM | #7 |
Re: A smoother ride
Also depends on the spring/shock system. My Fordor has aftermarket tubular shocks in back which makes for a choppy ride at low speeds. OK at higher speeds. You can adjust the stock shocks. You should adjust them for the season, summer vs. winter.
