Old 03-21-2023, 10:32 PM   #1
[email protected]
Default 1930 deluxe roadster stanchion question
Hi all. I'm trying to install my upper stanchions but the studs mounted to the factory lower stanchions seem to be too long even with the small s.s. washers. When I tighten the wing nuts, they bottom out before they get tight. Is there a spacer under the stanchion? Thanks.
lincofish@charter.net is offline   Reply With Quote
Old 03-21-2023, 11:38 PM   #2
Harpkatt
Harpkatt's Avatar
Default Re: 1930 deluxe roadster stanchion question
pg 78 of the brookville catalogue has an exploded view.
https://brookvilleroadster.com/wp-co...Reduced-X2.pdf
Harpkatt is offline   Reply With Quote
Old 03-22-2023, 07:57 AM   #3
Zax40
Zax40's Avatar
There should be a steel cup on the windshield side of the stanchion. Are you perhaps missing that?
Example in link https://www.mikes-afordable.com/product/A37137L.html
Zax40 is offline   Reply With Quote
Old 03-22-2023, 08:35 AM   #4
fundytides
fundytides's Avatar
If the steel cups mentioned above are not missing, they might be worn enough that the wing nuts do not hold the stanchion securely. On occasion, I have added one or two of the small stainless washers to compensate for the wear. Seemed to work ok and are not very noticeable
fundytides is offline   Reply With Quote
Old 03-22-2023, 07:07 PM   #5
kurt v
I needed one wingnut, ordered one from snyders , the repo's are cast a tad smaller, there for the hole could not be drilled deep enough making the same problem you have, bottoms out .
kurt v is offline   Reply With Quote
Old 03-22-2023, 08:50 PM   #6
[email protected]
Thanks all. Good info, I'll try some shimming tomorrow.
