#1 |
Does anyone have pictures of a 1CM crankshaft?
Thank you. |
#2 |
This photo set is from the HAMB on a for sale add. It's not real clean but the 1CM is visible.
https://www.jalopyjournal.com/forum/...troke.1112761/ The major change was the larger bore size in the rear flange to accommodate the automatic transmission torque converter. Other wise they are basically the same and interchangeable. |
#3 | |
Thank you for the response. This us what I get for posting too early in the morning. I wrote crankshaft when I should have written camshaft. I will start a new post. Thanks again. |
