Old 03-03-2023, 01:52 PM   #1
John MacDonald
Angry valves
did compression check on my 239, 59a everything seems ok coming out at 125 psi.but car will not start or idle, carb and fuel pump check out, poured gas down carb and backfire and smoke, timing or valves,give me your suggestions , condenser, coil, ran fine month ago ,sat then this ?? carb rebuilt last year, newer fuel pump. Help
John MacDonald is offline   Reply With Quote
Old 03-03-2023, 03:04 PM   #2
flatjack9
flatjack9's Avatar
Default Re: valves
Timing
Old 03-03-2023, 03:35 PM   #3
JayChicago
JayChicago's Avatar
Default Re: valves
Originally Posted by flatjack9 View Post
Timing
OP said: “ran fine month ago ,sat then this”
What would cause timing to change while sitting?
JayChicago is offline   Reply With Quote
Old 03-03-2023, 04:27 PM   #4
Lawson Cox
Lawson Cox's Avatar
Default Re: valves
My thoughts exactly. Vehicles are not affected by changing back and forth with daylight saving time. LOL and all that stuff.
Old 03-03-2023, 06:42 PM   #5
38 coupe
38 coupe's Avatar
Default Re: valves
Not valves, 125 PSI on all cylinders means the valves are moving and seating.
Diagnose the problem, fuel or spark. Verify spark before looking at fuel. Do you have a hot blue spark at the plugs?
Old 03-03-2023, 06:58 PM   #6
Alaska Jim
Alaska Jim's Avatar
Default Re: valves
fiber timing gear broke a few teeth while trying to start? I have seen it happen
Alaska Jim is offline   Reply With Quote
Old 03-03-2023, 07:07 PM   #7
tubman
tubman's Avatar
Default Re: valves
Especially if it's a current replacement. They have proven to be inferior. If you need to replace it, strongly consider an aluminum gear.
tubman is online now   Reply With Quote
Old 03-04-2023, 01:13 PM   #8
John MacDonald
Default Re: valves
must have spark because it backfired after pouring gas down carb,
Old 03-04-2023, 04:02 PM   #9
drolston
drolston's Avatar
Default Re: valves
Would you still get good compression readings it the timing gear broke some teeth?
- Check for a blue spark that will jump half an inch when cranking. If good, go back to the carb and fuel system. If not, Check:
- Coil wire fully inserted into coil and distributor. Primary connections and wires good.
- Check battery voltage at coil with points open; drop a couple volts with points closed. Nudge the engine rotation by crank pulley or shoving the car a bit in high gear.
- If all that looks good, pull the distributor, clean and adjust the points precisely. And replace the condenser.
Old 03-04-2023, 04:45 PM   #10
John MacDonald
Default Re: valves
checked spark, lit me up like a roman candle, check fuel pump next week, thanks guys
Old 03-04-2023, 05:43 PM   #11
flatjack9
flatjack9's Avatar
Default Re: valves
Would not get good compression on all cylinders with bad timing gear.
