03-02-2023, 06:44 AM | #1 |
Distance between water pump frame mounts on a C59A
I’m finally starting to build the frame for my speedster project and require the distance between the two water pump frame mounting homes. I have the engine (C59A) wrapped in plastic and really don’t want to remove it, plus the helmet dist is in the way. Ic. My one has the dimension it would be much appreciated as I couldn’t find anything on the interweebs.
03-02-2023, 08:30 AM | #2 |
Re: Distance between water pump frame mounts on a C59A
20" Exactly.
03-02-2023, 08:31 AM | #3 |
I'm showing 19 7/8" on my '40
03-02-2023, 09:51 AM | #4 |
