Old 03-01-2023, 03:27 PM   #1
Phil Gillespie
Phil Gillespie's Avatar
Default 1939 Ford Standard Coupe Doors
My query being:
Will doors off a 39 Ford standard sedan fit a 39 standard coupe? Or is there some work required? Understand there may be work required around top edge of door.
Appreciate any advice on this one.
Thanks Phil
Phil Gillespie is offline   Reply With Quote
Old 03-01-2023, 03:32 PM   #2
Kube
Kube's Avatar
Default Re: 1939 Ford Standard Coupe Doors
Originally Posted by Phil Gillespie View Post
My query being:
Thanks Phil
A fordor sedan door is close. The top edge is too tall (especially) at the B pillar and will have to be cut down to fit the coupe.
I have done this numerous times. I used to have a template so I could match the door to the opening on the coupe.
Not a terrible job at all but time consuming to do properly.
Old 03-01-2023, 07:11 PM   #3
Phil Gillespie
Appreciate your kind help and guideance.
Many thanks Phil NZ
Old 03-01-2023, 10:34 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
Many thanks Phil NZ
Phil..... I know that these are of the '35-'36 variety, but the difference is similar on the '39-'40 doors. Note that the extreme UPPER, REAR slope of the COUPE doors has already begun its slant downward as it follows the profile of the gutter. In other words, at this rearmost point on the door, you are already BEHIND the peak of the roof as it begins its slope downwards toward the rear. Hopefully, this gives you an idea of what you're up against.
Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 03-01-2023, 11:15 PM   #5
Phil Gillespie
Coop
Coop thats another great piece of info especially with a pic.
Thank you kindly for your advice.
Phil NZ
Old 03-02-2023, 07:44 AM   #6
Kube
Kube's Avatar
Coopman has offered some great photos. The '40 door requires more surgery than the 36 but again, you now have a better idea of what you're up against.
Old 03-02-2023, 03:53 PM   #7
Phil Gillespie
This site is full of very helpful people who kindly give great advice and share their knowledge freely for better understanding of many areas. The panel beater had another option to graft the top portion of the 39 coupe door onto the bottom section of a sedan door. So I'm confident it will be sorted.
Phil NZ
Old 03-03-2023, 11:04 AM   #8
Terry,OH
Terry,OH's Avatar
Can this be done with the 33-34 ?
Old 03-03-2023, 11:26 AM   #9
V8COOPMAN
V8COOPMAN's Avatar
Seems like I remember hearing tell of doing similar with 4-door sedan FRONTS on a 5-window coupe. 3-windows are out'a luck!
Coop
T5 W/TORQUE TUBE
