02-27-2023, 04:24 PM | #1 |
Vacuum Tee Check Valve Source
Hello everyone,
I have a 63 Galaxie with a 390 and I need help sourcing a part. I need the vacuum Tee / check valve that goes in the brake booster. This is an automatic transmission car so the Tee must have a large port for the manifold vacuum hose and a small port for the transmission vacuum. For some reason, this part seems to be hard to find. It looks like an inexpensive part, so I don't want to replace (or rebuild) the entire booster just for that one small part. Your help is very much appreciated! ---Rob |
02-27-2023, 05:39 PM | #2 |
Re: Vacuum Tee Check Valve Source
02-28-2023, 07:13 PM | #3 |
I have had trouble finding that part also. I was able to put a gromet in the hole then a locally available later model plastic part. works good
02-28-2023, 07:49 PM | #4 |
Is your check valve metal or plastic? 1963 FORD?
02-28-2023, 08:03 PM | #5 |
According to cataloging, that is a 1964/ .
- WANNA SEE A GOOD CAR WRECK? - https://www.youtube.com/watch?v=5oO226PgSkg KULTULZ - HAS MOVED ON TO THE HAPPY PROVING GROUNDS |
03-15-2023, 01:31 PM | #6 |
03-15-2023, 05:45 PM | #7 |
That looks similar to one Chrysler used from the 70's to the 90's on everything with power brakes. Not sure of the sizes though.
03-15-2023, 05:55 PM | #8 | |
... chirp ... chirp ... chirp ... ... occasional wolf howling at the moon ... chirp ... Quote:
https://www.ebay.com/itm/22524529696...Bk9SR-T7q9DSYQ The correct assembly parts are hard to come by.
- WANNA SEE A GOOD CAR WRECK? - https://www.youtube.com/watch?v=5oO226PgSkg KULTULZ - HAS MOVED ON TO THE HAPPY PROVING GROUNDS Last edited by KULTULZ; 03-15-2023 at 06:05 PM. |
03-15-2023, 06:40 PM | #9 |
I saw these, and the tees that go into the manifold in the last Original Parts group ElCamino catalog. Pictures and all. Lots of assortment.
03-15-2023, 08:20 PM | #10 |
Same booster i have in my 64 Tbird.
