Old 03-25-2011, 02:49 PM   #1
Jim Griffith
Default Overdrive Solenoid's
Gentlemen,
Can anyone tell me if there is a functional difference in a 4AR10B-62 and a 10AR10B-62 overdrive solenoid? Are they both 6 volt?
Additionally, does anyone rebuild the overdrive solenoids?
Thanks for your help.
Jim Griffith
Jim Griffith is offline   Reply With Quote
Old 03-25-2011, 03:26 PM   #2
jdl
jdl's Avatar
Send a message via ICQ to jdl
Default Re: Overdrive Solenoid's
Here is a good article on overdrive's including the solenoid application list.
click the link...
http://www.hemmings.com/hmn/stories/...feature29.html
jdl is offline   Reply With Quote
Old 03-25-2011, 10:47 PM   #3
Jim Griffith
Thanks JDL for the solenoid info. According to the info, both part numbers I listed are 6 volt.
Old 03-26-2011, 11:40 AM   #4
rotorwrench
rotorwrench's Avatar
Functionaly, all the solenoids work in a similar manner. The Nash & Hudson stuff I've come across all works same way as Ford/Mercury but has different mounting style or bolt pattern and some have longer or shorter actuator shafts.
There are folks out there that rebuild the coils & replace the points on these and there are new replacements for some makes available. The Fifth Ave Internet Garage sells reproductions that fit some models.
Kerby
Old 03-26-2011, 03:56 PM   #5
52merc
52merc's Avatar
fifth ave has new replacement solenoids 6volt & 12 you have to tell them the length of your shaft,
52merc is offline   Reply With Quote
Old 03-27-2011, 08:40 AM   #6
Mac VP
Mac VP's Avatar
Fifth Ave is sold out on solenoids. They are working on doing another production run. No time frame yet. So, it's fix-up time for now on existing solenoids.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
