Old 02-23-2023, 05:49 PM   #1
AnthonyG
AnthonyG's Avatar
Default Throttle body fuel injection?
Anybody running a throttle body FI on their Flatheads?
Nomad
AnthonyG is offline   Reply With Quote
Old 02-23-2023, 08:27 PM   #2
Tim Ayers
Default Re: Throttle body fuel injection?
If I recall, I believe the late Mike Davidson from Austria had set-up or fooled around with a set up.
I also seem to recall someone makes a FI unit that "looks" a 2 bbl carb. I forget who is making those. Demon maybe. Anyone recall?
Old 02-23-2023, 08:37 PM   #3
tubman
tubman's Avatar
There is a member here "Kilohertz" who has done this. Check this thread out : https://www.fordbarn.com/forum/showt...fuel+injection.
Old 02-23-2023, 08:38 PM   #4
Pete
I think Ray, (flat32) had one on his 32.
I drove it and it seemed to work pretty good.
Old 02-23-2023, 09:10 PM   #5
B-O-B
B-O-B's Avatar
My nephew had one they sold . They were made mostly in China. Infringement rights, poor sales, having a Chinese partner & blah blah blah led to the big "B". I think there was a writeup in one of the mags.
B-O-B is offline   Reply With Quote
Old 02-23-2023, 09:54 PM   #6
AnthonyG
AnthonyG's Avatar
I helped my son put one on his 67 327ci sbc! Basically same bolt pattern as the Edelbrock 4 barrel that he got it with. We added a threaded adapter for the Oxygen sensor to the exhaust, hooked 12v dc to the CPU supplied via the Vette’s fuse box. It had a smart phone size keyboard & screen to set up parameters & adjust. Started engine checked screen adjusted per instructions & took it out for a ride. Ran great! I’ll check the post & thread Tubman posted!
Thx
Nomad
Old 02-24-2023, 08:11 AM   #7
mfirth
Holley made one for a Y-Block. A friend had it on a 292, but sold the car before finishing the project.
mfirth is offline   Reply With Quote
Old 02-24-2023, 01:51 PM   #8
frnkeore
frnkeore's Avatar
Ford used one on the early '80's, 302 LTD's, that could be adapted to a FH. It has the Holley 2 bbl bolt flange on it.
Frank
'35 Ford Model 51
'48 Ford F3
'54 Ford Tudor Mainline
frnkeore is offline   Reply With Quote
Old 02-25-2023, 05:01 PM   #9
AnthonyG
AnthonyG's Avatar
Not sure if I’m explaining myself very well. A unit like this is what I’m talking about. I think the cpu supplied & setup is just powered by your 12V battery & inputs from ur distributor & a oxy sensor u need to integrate into your exhaust. Don’t think it cares what engine it’s on except your 4 barrel mounting holes on your manifold. https://www.classicindustries.com/pr...E&gclsrc=aw.ds
Nomad
Old 02-25-2023, 05:16 PM   #10
jimTN
I have a near neighbor who is setting these up on slant sixes with good success. He has mentioned doing a Ford FH, would be great for me but all my cars are still 6v.
jimTN is offline   Reply With Quote
Old 02-26-2023, 08:24 PM   #11
wga
wga's Avatar
Give FI Tech a call. They are in Riverside, Ca., with good tech help. Spoke with them at SEMA and was impressed with what they do.
https://fitechefi.com/
Henry Ford designed the flathead without the aid of a computer.
wga is offline   Reply With Quote
Old 02-26-2023, 08:46 PM   #12
Ken Henry
Ken Henry's Avatar
Here’s what I did on my 51. All custom made unfortunately, using Megasquirt and junkyard parts, but works great on my newly built 276ci. The video is of the system running on my old 239
https://youtu.be/opD4sg99HKQ
Ken Henry is offline   Reply With Quote
Old 02-26-2023, 08:49 PM   #13
Ken Henry
Ken Henry's Avatar
…and running on the new 276ci. Almost looks like carbs! Ken
https://youtu.be/jNpE10gqnb8
Old 02-26-2023, 09:10 PM   #14
tubman
tubman's Avatar
Ken,
Did you used to be "KiloHertz"? I thought the car looked familiar.
Old 02-26-2023, 10:13 PM   #15
Ken Henry
Ken Henry's Avatar
No, I did post on his thread though. His name is Paul and he used a GM TBI
Old 02-26-2023, 10:35 PM   #16
tubman
tubman's Avatar
Sorry, I guess I didn't know that this many people were interested in this.
Old 02-28-2023, 08:20 AM   #17
Ken Henry
Ken Henry's Avatar
Main advantages are faster starting after sitting for several weeks and perhaps 5-10% better fuel economy in my case. I thought it would quiet my wife down about the exhaust odor. Nope, the idle still needs to be pretty rich for smooth running, maybe 12:1 AFR on my meter… Ken
Old 02-28-2023, 09:41 PM   #18
AnthonyG
AnthonyG's Avatar
Very 😎!!!
Nomad
Old 03-01-2023, 12:10 PM   #19
Pantera5725
My 35 Coupe has been converted to fuel injection for the past 2 years. Motor is a 50 Mercury with an Edelbrock 4 barrel manifold and an 88 Chevrolet S10 pickup 4.3L V6 TBI. Runs well with an occasional problem of erratic idle speed which I have yet to sort outDSCN2722.jpg
Pantera5725 is offline   Reply With Quote
