Old 02-22-2023, 08:02 PM   #1
dad's deuce roadster
dad's deuce roadster's Avatar
Default advice on a steering wheel to look correct on 50's low boy rod
Well, the rebirth of our Dad's 32 low boy roadster continues. It is now even registered, plates and all. Let's just say that walking into the DMV with a 1955 transferable registration for a 32 Roadster leads to some interesting conversations.
That aside, the engine still needs some tuning, but is running much better. Thanks to the guys who provided input on that thread.
We now come to some of the niceties, in this case a steering wheel. The current wheel is not original. And at 17" is not real conducive to comfort in channeled roadster. My father is 5' 8" and weighed 140 back in the day. I'm 6' (got that from my mother's side) and 190 and find the wheel just tolerable. I'd like to find something that is 50's rod period correct in the 15" range. Any thoughts
dad's deuce roadster is offline   Reply With Quote
Old 02-22-2023, 08:12 PM   #2
Alaska Jim
Alaska Jim's Avatar
Default Re: advice on a steering wheel to look correct on 50's low boy rod
There is a '40 style steering wheel that is a reproduction, and is 15" diam. not sure who is selling them
Alaska Jim is offline   Reply With Quote
Old 02-22-2023, 08:16 PM   #3
Tim Ayers
It all depends on your budget, but the sky is the limit. As Jim mentioned, banjo and '40 style wheels are available in the aftermarket in 15" diameter.
The hot ticket for a '50's rod is a Crestliner wheel. A good core is $800-$1,000. Then send it to a vendor like Steering Wheel Kris to get it refurbed and resized to 15", add another $1,000-$1,500, but it would be the bee's knees in terms of a '50's hot rod steering wheel.
Old 02-22-2023, 09:17 PM   #4
For sure, budget is the issue. Had we thought about a different wheel on round one of this project, aka the 1970's, there was no end of the cool wheels we could have found in the junkyards for a couple bucks. Anyway, now we're talking what can we do for a couple hundred.
Old 02-22-2023, 09:19 PM   #5
Kurt in NJ
Kurt in NJ's Avatar
Model T wheel?
Diameter range of 14-1/2 to 17”
Old 02-22-2023, 09:33 PM   #6
Tim Ayers
Someone makes a 15" Bell four spoke that is pretty much timeless.
Old 02-22-2023, 11:14 PM   #7
fordor41
fordor41's Avatar
the smaller the wheel the harder it is to turn
fordor41 is offline   Reply With Quote
Old 02-23-2023, 02:07 AM   #8
my4dv8
Look at a VW banjo steering wheel on Ebay. Change the centre to your ford taste and modify the bands on the spoke to look ford , 15” and they fit a ford key way shaft .
my4dv8 is offline   Reply With Quote
Old 02-23-2023, 02:29 AM   #9
47topless
47topless's Avatar
A 1940 Ford wheel would look great.
47topless is offline   Reply With Quote
Old 02-23-2023, 06:26 AM   #10
FHFD
FHFD's Avatar
Steering wheels are such an important part of the cars interior vibe...very important for it to be in theme with the entire era/build.
Let's see some pics of the car, along with its interior.
"Get your facts first..then you can distort them as you please"
FHFD is offline   Reply With Quote
Old 02-23-2023, 09:45 AM   #11
rhphotord
rhphotord's Avatar
Had an original 40 in my 30 roadster and found it was a tad large so went with an aftermarket 15" dia. Looks great and not a problem steering at all.
rhphotord is offline   Reply With Quote
Old 02-23-2023, 09:51 AM   #12
51504bat
51504bat's Avatar
Lime works might have something that would work
https://www.limeworksspeedshop.com/S...Kits-s/478.htm
Old 02-23-2023, 10:18 AM   #13
Tim Ayers
I forgot Limeworks makes a Crestliner wheel. If it was me, I'd fine a way to get one of those. Those are the tops for a '50's style hot rod in my opinion.
Old 02-23-2023, 11:59 AM   #14
Here's another thread with a pic. There is effectively no interior yet. Just a couple 65 or so Mustang buckets. Some guy never paid for the work done on it at my grandfather's garage, so we appropriated the seats temporarily, that was about 1974. Now wish I had appropriated the whole Mustang.
https://www.fordbarn.com/forum/showthread.php?t=321859
Old 02-23-2023, 12:01 PM   #15
It is a gorgeous wheel, but the cost is not in the budget. If I could pick up a ratty one for a few hundred it could work as the car is about half rat rod.
Old 02-23-2023, 12:10 PM   #16
Tim Ayers
I hear ya. '40 wheel would be my second choice for your car. A '48 wheel would also be an excellent choice and can be found for around $200-$300 in usable condition.
Does the car still have a tapered steering shaft? Depending on the wheel you pick, If memory serves me correctly, you may need to cut another groove in the shaft or wheel for the woodruff key location changed through the years.
Old 02-24-2023, 12:12 PM   #17
TJ
TJ's Avatar
I would suggest using the VW banjo steering wheel. You can find them for less than $300 on e-Bay and it uses any Grant style adapter to fit other columns. If you are using an early column you can get the keyway adapter from Speedway. The wheel looks just like a '36 banjo wheel and is 15" in diameter. I bought one and the quality is excellent.
Old 02-24-2023, 12:18 PM   #18
Tim Ayers
A great book to use as reference for a '50's style build is Andy Southard, Jr's Hot Rods of the '50's
Old 02-24-2023, 03:27 PM   #19
TJ
TJ's Avatar
Just checked e-Bay and the cheapest VW Banjo is now $312 with free shipping. Bought mine about 6 mo. ago and paid $268 with free shipping. Bidenflation.
Old 02-24-2023, 04:17 PM   #20
47topless
47topless's Avatar
Thumbs up Re: advice on a steering wheel to look correct on 50's low boy rod
Looks like a great book. Thanks for the suggestion. Just ordered a copy. Will be a good read as I rehab from knee surgery.
Phil
