Old 02-15-2023, 07:53 PM   #1
Roger W Gerow
Default lubrication for speedometer cable
Search did not locate information. I've removed entire speedometer cable and housing. They have been cleaned up with solvent. Now, open to suggestions on what to use for lubrication. HELP!
DD658
Roger W Gerow is offline   Reply With Quote
Old 02-15-2023, 09:04 PM   #2
Zeke3
Zeke3's Avatar
Default Re: lubrication for speedometer cable
I have used speedometer cable lube that is a graphite powder.
Zeke3 is offline   Reply With Quote
Old 02-15-2023, 10:56 PM   #3
fordor41
fordor41's Avatar
I've used silicone grease with good luck. Used on disc brake pins, can find at auto parts stores.
fordor41 is offline   Reply With Quote
Old 02-16-2023, 09:15 AM   #4
pistonbroke
They used to sell speedometer cable lube in a little tube about the size of your thumb. I think it was SAE 30 with graphite powder in it as it was black as sin and about that viscosity. I also used it in the speedometer head as well with great results. Tim
pistonbroke is offline   Reply With Quote
Old 02-16-2023, 09:29 AM   #5
19Fordy
19Fordy's Avatar
Roger, also make sure your speedometer cable is installed straight into the back of your speedo without any sharp bends. I use a wire tie to support mine in a 40 Ford.
I would hesitate about using oil or grease as they hold contaminents and dry out.
Old 02-16-2023, 09:32 AM   #6
Seth Swoboda
Seth Swoboda's Avatar
I have used white lithium grease on mine with success.
Seth Swoboda is offline   Reply With Quote
Old 02-16-2023, 09:53 AM   #7
51504bat
51504bat's Avatar
I use this from Dorman
https://www.dormanproducts.com/p-565-03344.aspx
or Lock Ease from Ace and other places.
Old 02-16-2023, 11:42 AM   #8
Roger W Gerow
Thanks for all the neat replies. Wonder what would happen if I mixed graphite powder with lithium grease?
DD658
Old 02-16-2023, 12:47 PM   #9
Fritz
Fritz's Avatar
I had a bouncing speedometer needle and researched speedo cable lube. I kept finding the recommended lube is graphite. Not sure about the Dorman tube now, but it was not in stock anywhere a couple months ago. So, I bought a big spray can of Slip Plate Chain and Cable graphite lubricant at Napa. It worked like a charm.
https://www.napaonline.com/en/p/BK_3...pressionRank=7
Cars and metal rust away and are destroyed, but the Word of God will stand forever (Isaiah 40:8, Matthew 24:35).
Fritz is offline   Reply With Quote
Old 02-16-2023, 02:14 PM   #10
1948F-1Pickup
1948F-1Pickup's Avatar
I did the truck a few years back by cleaning the core and housing and then mixing white grease and graphite….. which I then liberally applied to the core. Between that and a clean & lube on the speedo head, my needle has been rock steady.
1948F-1Pickup is offline   Reply With Quote
Old 02-16-2023, 04:05 PM   #11
Flathead Fever
Flathead Fever's Avatar
Originally, we used white lithium brake grease at the phone company because that's what we had. 400 speedo cables at that facility that would eventually get noisy. The safety department had a list of approved chemicals we were allowed to have and if it wasn't on the approved MSDS list we couldn't have it. Later on, we used the synthetic disc brake caliper slide grease on the speedo cables, brake caliper slides and the drum brakes' backing plates where the shoes move on them. I wouldn't mix different types of grease.
Great invention those electronic speedometers with speed sensors instead of cables.
Flathead Fever is offline   Reply With Quote
Old 02-16-2023, 04:26 PM   #12
Alaska Jim
Alaska Jim's Avatar
I have had good luck soaking the inner cable in an old metal coffee can filled with Automatic transmission fluid. let it soak over night. let the excess drip off the cable then reinsert it in the "sheath". It can be messy, but it has worked for me many times. This method may not be for everyone, because of the mess. do not wipe the cable off after soaking it , just let the excess drip off
Alaska Jim is offline   Reply With Quote
Old 02-16-2023, 06:16 PM   #13
1948F-1Pickup
I agree. Graphite in white grease is ideal because graphite isn’t a grease.
Old 02-16-2023, 06:46 PM   #14
Merc Cruzer
Merc Cruzer's Avatar
Not sure what car you have, but mine is a 53' Merc. I use 3 in 1 oil here (see arrow or the same location on your spedo). I find that most of the "bounce" can be eliminated, by oiling this point quite often. You can use it on the cable too.
Merc Cruzer is offline   Reply With Quote
