Old 01-31-2023, 07:15 PM   #1
Dennisfly
Dennisfly's Avatar
Default 35 Tudor Lights
Two newby questions:
The low element of my right headlight is out. I released the spring latch on the bottom of lens but it will not come off. Am I missing something? I tried rotating and pulled pretty hard, but no joy.
My dome light doesn't work. I need to remove the lens to access the bulb. Pulled pretty hard and tried prying with a screw driver, but didn't come off. I don't want to break it. What now?
1929 Town Sedan (Briggs) 155B, Mitchell Overdrive
1935 Model 48 Tudor
Dennisfly is offline   Reply With Quote
Old 01-31-2023, 09:09 PM   #2
Brian
Brian's Avatar
Default Re: 35 Tudor Lights
To remove the headlite bezel, after unlatching it at the bottom like you have, just pull it from the bottom forward and up. Maybe, because it's been in place so long it is somewhat stuck. You may want to use a narrow plastic blade or similar to just lever it from the bottom. use plastic or something similar to avoid chipping the paint on the h'lite bucket.
The dome lite lens is held in place with a wire 'snap ring around it's periphery. You'll need to use a narrow bladed screwdriver or similar to prise it off.
Unfortunately, two half wits don't make a whole wit!
Brian is offline   Reply With Quote
Old 02-02-2023, 07:23 PM   #3
Dennisfly
Dennisfly's Avatar
Brian,
Thank you. I always get good information from you half way around the world. With a pry tool, I was able to get the headlight retainer and lens off. It looks like the previous owner had just replaced the reflector, lens, etc. There was a new gasket that made it tight, but I got it off, replaced the bulb and all is good now. I checked the dome light switch with a meter and it looks like that is the problem instead of the bulb. I plan on taking the upholstery off in that area to replace the glass so I will deal with it then. Thanks again for the help.
1935 Model 48 Tudor
Old 02-02-2023, 09:34 PM   #4
Brian
Brian's Avatar
Dennis, you are welcome; enjoy the 35, they are fine cars.
