Old 01-23-2023, 12:47 PM   #1
Rusty30roadster
Default Boling bros battery tray - dual master cylinder?
Has anyone mounted a dual master cylinder on a boling brothers battery box, on a stock model a chassis, with stock pedals? I’m trying to figure out how to do this and any help, advice, or pictures of your project would be very helpful.
The battery tray is only sold with a single cylinder, and I think I’m going to need to fabricate a bracket to attach a standard dual master cylinder onto the battery box. I’m going to start mocking things up, but wanted to check with you all to see if you can help me learn faster through your experiences. I’m hoping that a bracket will keep the master cylinder aligned still with the stock pedal linkage.
Thank you for any help, J
Rusty30roadster is offline   Reply With Quote
Old 01-24-2023, 12:31 PM   #2
Jim Brierley
Default Re: Boling bros battery tray - dual master cylinder?
I only use one cyl. but also use DOT-5, silicone, brake fluid. It doesn't attract water like other fluids, so the cylinders don't get rusty, and last eons.
Jim Brierley is offline   Reply With Quote
Old 01-24-2023, 01:05 PM   #3
jeepguy1948
Mine had a dual master cylinder on it. Unfortunately I no longer have it so I can’t give you specifics but I don’t think anything special had to be done, the mounting pattern is the same either way.
jeepguy1948 is offline   Reply With Quote
