Old 01-19-2023, 05:34 PM   #1
Randy1944
Randy1944's Avatar
Default Water pump gaskets
1946 Ford v8 flathead. Installing Haney rebuilt water pumps. What is good source for best gaskets to use? Thanks
Randy1944 is offline   Reply With Quote
Old 01-19-2023, 06:13 PM   #2
Angledrive
Angledrive's Avatar
Default Re: Water pump gaskets
You answered your own question. Best Gaskets, Call Mike at Third Generation
Angledrive is offline   Reply With Quote
Old 01-19-2023, 07:44 PM   #3
Ken Henry
Ken Henry's Avatar
I think Skip includes gaskets.
Ken Henry is offline   Reply With Quote
Old 01-19-2023, 09:38 PM   #4
JM 35 Sedan
JM 35 Sedan's Avatar
He has supplied gaskets on all of the sets he has built for me, and they looked just like the gaskets that Best Gasket Co sells.
John
Old 01-20-2023, 08:43 AM   #5
Jacques1960
Jacques1960's Avatar
And Indian Head sealer
No job’s done ‘til it’s all done
Jacques1960 is offline   Reply With Quote
Old 01-22-2023, 07:44 AM   #6
Talkwrench
Talkwrench's Avatar
Or do what I do, I get my daughter to make them while she's sitting around not doing much
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 01-22-2023, 01:08 PM   #7
v8fordman
v8fordman's Avatar
How many pairs do you need? I have plenty NOS or reproductions. [email protected]
v8fordman is offline   Reply With Quote
Old 01-22-2023, 02:31 PM   #8
Krylon32
For my water pump kits I have always used the Fel Pro blue gaskets.
Krylon32 is offline   Reply With Quote
Old 01-22-2023, 02:52 PM   #9
tubman
tubman's Avatar
With the price of commercial gaskets these days. I make all the simple ones (such as this) myself
Old 01-23-2023, 09:28 AM   #10
51504bat
51504bat's Avatar
I've had Skip rebuild 2 sets of Merc pumps. Both came with gaskets but on the first set the gaskets were on the bottom of the box and not easily visible IIRC. On the second set I knew to look for them. My guess is that Skip did send gaskets but you missed them when you opened the box. Just a guess.
Old 01-23-2023, 01:02 PM   #11
Randy1944
Randy1944's Avatar
Many thanks for all the help. I have bought these water pumps from a third party and haven’t received them yet. He didn’t mention gaskets so I was just trying to get ahead and have some on hand. I’ve appreciated the work Skip does on coils and bought these water pumps as a backup set, feeling that Skip did a good job on these. Have a great day.
Old 01-24-2023, 06:24 PM   #12
ford38v8
ford38v8's Avatar
Randy, do yourself a favor and use only a bit of grease to hold on your gasket during assembly. Gasket cement is not needed (it won't leak), and is difficult to scrape off during the next pump replacement. The same is true for the rubber hoses. Silicone is best for the hoses, helps them slide on easier and preserves the rubber. Tip here is to go back and tighten the clamps after the hoses heat up with hot water flow.
Alan
