Old 01-15-2023, 02:30 AM   #1
Ian Curtis
Ian Curtis's Avatar
Default Combustion Chamber Pitting
I pulled the head looking for the source of a large cloud of steam on my '29 pickup. I found a crack in the head, so nice to have some resolution there. But that's not what I'm asking about. While the head was off I noticed lots of pitting in the combustion chamber of #4. There is some pitting in #2, and very little in #1/#3. The current pistons have no damage. See picture at the bottom of this post (pitting to the left of the hand)
I assume what caused this pitting is engine knock (detonation) at some point in the past? If that's the case, why is one cylinder so much worse than the others? I would think if you had something that made one cylinder knock (too much compression, wacky timing) they'd all knock and so you'd expect similar damage in all cylinders?
"It is much easier to call someone else a genius than admit to yourself that you are lazy." - Dave Gingery
Ian Curtis is offline   Reply With Quote
