Old 03-23-2011, 08:51 AM   #1
dan
dan's Avatar
Default Quick fix for electrical discharge
So, yesterday it rained (lightly) on the way home from work. (Yes, I can hear the shudders and groans from the "My A never gets wet" crew) By the time I got home the car had dried and I parked it in the garage as usual. This morning, it started a little hard, like the battery was weak. On the way in, I noticed that the ammeter showed constant charging (I have an alternator) and when I parked the car it was showing a slight discharge. I pulled the fuse at the starter and disconnected the fuse that runs the accessories (turn signals, etc) but am still showing a discharge. When I checked, the top of the battery did get a little wet on the way in (rain again this morning) but I dried it off and still no joy.
Since I'm parked in the garage at work and have only a limited set of hand tools, I'm not going to be able to diagnose/correct this until I get home. But in order to get home, I have to be able to start the car this afternoon :-) I'm guessing the only way to stop this dead is to disconnect the battery. Should I just take the clamp off the positive terminal, or pull both?
On another note, the odometer just turned 89,600 which means that I have put just about 2,500 miles on the car in the last eight months. I drive it to work every day, but I wish I got to drive it more. For those of you who've had your car a long time, do you ever get tired of driving it?
dan is offline   Reply With Quote
Old 03-23-2011, 08:55 AM   #2
31Tudor
31Tudor's Avatar
Default Re: Quick fix for electrical discharge
Dan, you would only need to pull off one of the battery cables to disconect the battery.
31Tudor is offline   Reply With Quote
Old 03-23-2011, 09:31 AM   #3
Cool Hand Lurker
Cool Hand Lurker's Avatar
If you pulled the main fuse at the starter there should be no current running through the ammeter. If you have a test light, connect it between ground and one of the terminals on the terminal box. It should not light with the fuse removed. Then if the ammeter still shows discharge there is probably something wrong with the ammeter, maybe just a bent needle.
Cool Hand Lurker is offline   Reply With Quote
