Old 11-22-2022, 04:43 PM   #1
Bob56
Bob56's Avatar
Default 1936 Exhaust
Where can i get a complete exhaust for 1936 club cabriolet that is not made in China? Would like concourse correct. I have the correct muffler. That is what i was going to change but everything on the old system has been tack welded together
Bob56 is offline   Reply With Quote
Old 11-23-2022, 02:57 AM   #2
deuce lover
deuce lover's Avatar
Default Re: 1936 Exhaust
Here: Concours correct?
https://www.google.com/url?sa=t&rct=...zC_IwMWGnmK9zr
deuce lover is offline   Reply With Quote
Old 11-23-2022, 04:28 AM   #3
DavidG
DavidG's Avatar
Sheldon,
With respect, that exhaust system on ebay is not "concourse correct".
Correct crossover pipes aren't a big challenge, nor is the correct muffler. The muffler inlet pipe and and tail pipe will prove to be the most elusive. Third Gen and Southside Obsolete are likely your best bets for NOS pipes and mufflers, as well as the correct brackets and clamps. The overall cost will likely not be cheap, by any means.
Old 11-23-2022, 04:51 AM   #4
deuce lover
David,That is why I questioned it.
Old 11-23-2022, 07:31 AM   #5
KiWinUS
KiWinUS's Avatar
Bob I have a NOS front crossover pipe I would sell.
KiWinUS is online now   Reply With Quote
Old 11-23-2022, 10:32 AM   #6
Seth Swoboda
Seth Swoboda's Avatar
As David said, NOS can be found. It won't be cheap. The two folks David mentioned are your best resources. They are probably your best parts resources for anything authentic and "concourse correct".
If you were to combine the Third Gen and Southside Obsolete businesses you would create an Early V8 Ford superstore.
Seth Swoboda is offline   Reply With Quote
Old 11-23-2022, 12:45 PM   #7
tubman
tubman's Avatar
So true. I can't believe how many times someone has posted a desperate request for some part that I would think no longer exists.
The next post on the thread will be from "barnfind08" saying simply : "I have those".
Old 11-24-2022, 08:39 AM   #8
Bob56
Bob56's Avatar
Thanks everyone. Southside Obsolete has everything I need
