11-18-2022, 08:57 PM | #1 |
Very late Model A block - any other info?
I have a Model A engine block with Serial #4869355. Vince Falter's website shows it to be made sometime in 1937. I'm wondering if it powered a Baldwin Gleaner combine, or was it made as a replacement block for automotive use? I'm interested in finding out more about what it was used for since it was cast so many years after the end of Model A engine production.
11-18-2022, 09:56 PM | #2 | |
Re: Very late Model A block - any other info?
www.whidbeymodelaclub.com Last edited by Gary WA; 12-30-2023 at 02:37 PM. |
11-18-2022, 09:57 PM | #3 |
Is this a diamond block with exhaust valve seat inserts and B cam ?
11-18-2022, 09:59 PM | #4 |
yes and should be a small plate with a date on it. behind oil tube as you can see on above motor not sure of the B cam
www.whidbeymodelaclub.com |
11-18-2022, 11:03 PM | #5 |
All very good questions. I'll have to check the block and report back.
11-19-2022, 11:19 AM | #6 |
11-19-2022, 03:25 PM | #7 |
I can't remember - what was the significance of the Diamond casting?
11-19-2022, 03:58 PM | #8 |
Good afternoon...A diamond block was a block built as a replacement block after the last of the Model A's were built. They were built almost up to World War II. If you needed a new block...you could get one from Ford. Ernie in Arizona
11-19-2022, 03:58 PM | #9 |
The diamond indicates the casting came from a contractor, not a Ford foundry
As Carroll Smith wrote; All Failures are Human in Origin. |
11-19-2022, 04:21 PM | #10 |
They were also used later in farm and construction implements.
I have one that has an AC # (Allis Chalmers). Everything standard Often those items didn’t have as many hours on them as cars |
11-19-2022, 07:23 PM | #11 |
Were the Diamond blocks known to be a better quality casting, or did they posses any other special attributes to make them more desirable than the normal Model A blocks, such as better alloy content?
11-19-2022, 07:40 PM | #12 | |
lots of info your looking for on this Great site. Thanks to site owner for its use.
11-19-2022, 08:08 PM | #13 |
Yes, Vince Falter's website is a treasure trove of Model A info.
11-19-2022, 08:16 PM | #14 |
MC, That diamond block was built for you to come across in 2022.
11-20-2022, 02:25 PM | #15 |
nkaminar;
Now if I just had a car to put it in! |
11-20-2022, 04:30 PM | #16 |
First time I have heard that.
11-21-2022, 12:57 PM | #17 |
As far as I've seen, the Baldwin Gleaner pull type combine engines have a "G" prefix on the engine serial number. This is Vince's info and consistent with what I've seen.
https://www.fordgarage.com/pages/gleanerbaldwin.htm Last edited by rotorwrench; 11-21-2022 at 10:13 PM. |
11-21-2022, 01:10 PM | #18 |
The engine that is currently in my car has a number that indicates it is a 1934 factory built replacement motor.
11-21-2022, 01:50 PM | #19 |
Interesting information about the Gleaner engine numbers beginning with "G" and makes perfect sense in that context. My block has the "A" prefix before the serial number, so I suppose that would make it a replacement block for automotive use.
11-21-2022, 09:34 PM | #20 |
I have a Gleaner diamond block. The number is G733
Dave / Lincoln Nebraska |
