11-17-2022, 07:49 PM | #1 |
39 ford flathead 239 ci.
Where does the positive battery cable get grounded to? the head?
11-17-2022, 07:56 PM | #2 |
49 ford flathead v8 239 ci
It is a 49, and not a 39
11-17-2022, 09:20 PM | #3 |
Re: 39 ford flathead 239 ci.
My 52 Merc has the ground cable going to the intake manifold. Seems to work well but I have no idea if this is original. I've heard the best results come from running a ground cable direct from the battery to one of the starter bolts.
https://www.youtube.com/user/roosty6/videos |
11-17-2022, 09:48 PM | #4 |
There is a threaded hole in the very front of the LH cylinder head. You can barely see it in the attached picture (circled). 5/16-18 thread I believe.
11-17-2022, 11:02 PM | #5 |
11-18-2022, 07:43 AM | #6 |
11-18-2022, 08:24 AM | #7 |
On cars the generator wiring clamp is on the rear thermostat housing bolt.
