Old 11-14-2022, 10:19 AM   #1
kingskid
Default 47 coupe shocks
My 47 has front and rear tube type shocks. Would like to replace them. Any brand or numbers? Thanks.
kingskid is offline   Reply With Quote
Old 11-20-2022, 03:59 AM   #2
1oldtimer
1oldtimer's Avatar
Default Re: 47 coupe shocks
I ended up with cheap Monroe matics, because I had KYB on it and it was too stiff. You really need to measure them and choose, all depends what brackets you have on it.
1oldtimer is offline   Reply With Quote
Old 11-21-2022, 02:24 PM   #3
Als48
If I remember correctly, the shocks for my '48 were the same as an early '70's Chevy C10 pickup.
Al Hook
Als48 is offline   Reply With Quote
Old 11-21-2022, 02:53 PM   #4
bobH
For my 47, I simply went to Auto Zone and asked for shocks for a 47 Ford. Simple. And, at the time, I was able to get old-style hydraulic shocks... not N2 filled. Factory brackets were already on the car.
bobH is offline   Reply With Quote
Old 11-22-2022, 04:14 PM   #5
TJ
TJ's Avatar
Also try Napa auto parts and use the Napa brand shocks. I think post #3 by Als48 is correct. I used the shocks from the early 70's C-10 pickup on a '46 Ford coupe.
Old 11-22-2022, 04:37 PM   #6
tubman
tubman's Avatar
I'd look a little more. The C10 shocks may fit, but they are for a vehicle that weighs at least 50% more than a '47 Ford. If you like a stiff ride, they may be OK, but there may be better choices.
Old 11-23-2022, 11:22 AM   #7
TJ
TJ's Avatar
I used the Napa Brand and they worked just fine. No noticeable stiff ride.
