Old 11-13-2022, 12:49 PM   #1
cbabek
cbabek's Avatar
Default 37 steering box issue
All,
I have a 37 gemmer style steering box in a 36 and I am having some backlash issues.
when the sector is in the middle and the gears are adjusted with minimal drag - when the wheel is turned to either left or right there is significant play in the box.
I replaced the worm gear that looked a little worn with the same 18:1 gear.
same thing
about 5/16 to 3/8 play at the end of the pitman arm.
Pulled it apart again - gears not meshing tight when turned away from center
not sure what's going on here
is this not the right sector for this box ? are there other ratios other than 18 for this box. ?
II cant imagine this is correct.
any help would be appreciated
cbabek is offline   Reply With Quote
Old 11-13-2022, 01:54 PM   #2
Andy
Default Re: 37 steering box issue
That is typical with good gears. The gears were designed to be tight in the middle and loose off center. This is so when the center position wears down and the sector is moved in, the box will not be excessively tight off center.
Andy is offline   Reply With Quote
Old 11-13-2022, 02:06 PM   #3
cbabek
cbabek's Avatar
i expected that - but its excessive - I wish I could post video - I would expect 3/16 or a 1/4 - but not 3/8
Old 11-13-2022, 02:23 PM   #4
glennpm
glennpm's Avatar
Here are the directions
File Type: pdf Flathead 37 to 48 Steering Gear Adjustments.pdf (385.1 KB, 59 views)
Old 11-13-2022, 02:24 PM   #5
cbabek
cbabek's Avatar
Video link
https://www.youtube.com/shorts/Ivq8KG5XhDc
Old 11-13-2022, 03:34 PM   #6
Ggmac
When your wheel is turned , the pressure from the car is holding the pitman arm firm . Im not sure Im explaining this correctly but I hope you can imagine a car in hard left or right turn , theres no way the play could hurt anything.
Ggmac is offline   Reply With Quote
Old 11-13-2022, 06:43 PM   #7
Mart
Mart's Avatar
The free play at the ends of travel is normal.
If you can't adjust all the free play out in the straight ahead position that is when you are in trouble.
Just get the play down to zero with the faintest hint of drag on the middle and don't worry about anything else.
I showed setting up an f1 box in a video. If I can find it I'll put a link here.
Mart.
Old 11-14-2022, 08:01 AM   #8
Terry,OH
Terry,OH's Avatar
Is there play in the worm and steering shaft. there is a special washer on the top of the worm that is adjusted with gaskets to apply a lot of pressure to the worm and it's bearings and races.
Old 11-14-2022, 11:42 AM   #9
NealinCA
NealinCA's Avatar
Like Mart and others have said, adjust the play out in the centered/neutral position, but there is play designed into the box as you get off center. The force of the turn will load the gears in the box, eliminating that play when driving. That clearance (play) also allows the box to easily come back to center when coming out of a turn.
Neal
NealinCA is offline   Reply With Quote
