11-07-2022, 05:24 PM | #1 |
flathead Ford 239 ci. Oil cannister
1949 8ba 239 ci. ford v 8. The oil cannister has three holes in it. Input, output and is the third hole for a drain? thanks
11-07-2022, 05:31 PM | #2 |
Re: flathead Ford 239 ci. Oil cannister
yes.
11-08-2022, 10:24 AM | #3 |
Oil goes in through the upper side , out through the bottom center and the angle bottom port is a drain to empty the canister when doing a oil change. Tim
11-08-2022, 01:06 PM | #4 |
