Old 11-02-2022, 12:03 PM   #1
Canton_Model_A's
Canton_Model_A's's Avatar
Default Syners Grease Fitting set - Modern Style
Hello,
I just purchased the Grease Fitting Set, Modern style for my 1928 I also got the press. My question to the crew here is, if I see threads on these can I use the press to put them into the holes that are on my front Brake actuator part.
Thanks!
Canton_Model_A's is offline   Reply With Quote
Old 11-02-2022, 12:38 PM   #2
Curtis in MA
Default Re: Syners Grease Fitting set - Modern Style
Make sure they are threads and not ridges.
Press in have ridges.
Curtis in MA is offline   Reply With Quote
Old 11-02-2022, 04:33 PM   #3
john in illinois
john in illinois's Avatar
If the old fittings were not threaded,then tere are no threads.
The new style fittings I have used are too big and will not drive in. Try one,yours may be ok.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 11-02-2022, 08:14 PM   #4
fundytides
fundytides's Avatar
I also can not drive in the new style fittings
fundytides is offline   Reply With Quote
Old 11-03-2022, 07:07 AM   #5
Werner
Werner's Avatar
That's my problem too!
Beste Gruesse aus Deutschland,
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 11-03-2022, 07:18 AM   #6
Fhane
Fhane's Avatar
Curtis in MA has it right. Compare the threaded fittings to the fittings with ridges, side by side. The drive in with the ridges have a smaller diameter than the threaded fittings. At least they work for me. If not, check with Snyders.
Fhane is offline   Reply With Quote
Old 11-03-2022, 08:37 AM   #7
31Tudor
31Tudor's Avatar
The front actuator has press in grease fittings. If you see threads then someone before you threaded them.
31Tudor is offline   Reply With Quote
Old 11-03-2022, 04:22 PM   #8
john in illinois
I used the press in new style by carefully using a grinder around the circumference to get a press fit. Trial and error.
John
Welcome each day
Old 11-05-2022, 06:55 AM   #9
denis4x4
denis4x4's Avatar
When I rebuilt the front ends on my A's, I tapped the grease fitting holes and used the screw in grease fittings.
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 11-05-2022, 04:27 PM   #10
john in illinois
That is the best way to do it. On my parts the existing holes were too big fpr 1/8 pipe and not enough meat to go 1/4”.
Welcome each day
