Old 10-29-2022, 09:57 AM   #1
jason_is_here
Default are disc brake conversions bad ?
I was reading somewhere that some people say they're bad because the straight axle design.
Something about it puts twisting force on it ?
jason_is_here is offline   Reply With Quote
Old 10-29-2022, 10:25 AM   #2
Will N
Will N's Avatar
Default Re: are disc brake conversions bad ?
Bad? No. Unnecessary? Yes.
Will N is offline   Reply With Quote
Old 10-29-2022, 10:29 AM   #3
Bob C
Wouldn't any brake put a twisting force on the axle?
Old 10-29-2022, 10:49 AM   #4
GeneBob
Regardless of brake system, your limiting factor will be the traction of the tires on the ground.
So, as many on the Barn will relate, the stock brakes do not need to be changed. I have kept my stock brakes and they will lock up the tires so changing to hydraulics of any flavor must have other considerations to factor in like changing the drivetrain.
GeneBob is offline   Reply With Quote
Old 10-29-2022, 11:48 AM   #5
Jim Brierley
Stock brakes in good condition are fine for driving at 45 MPH. If you drive faster, or with modern cars, or hilly country, you need a better brake. As stated by Bob C, all brakes tend to twist the axle but the A axle is plenty strong to handle that.
Jim Brierley is offline   Reply With Quote
Old 10-29-2022, 11:57 AM   #6
jason_is_here
Yes I realize any brake would cause a twist but obviously some more so than others.
Ok doesn't sound like I'm gonna be causing any major issues by using them.
Thanks again
Old 10-29-2022, 12:43 PM   #7
jeepguy1948
Jason, the twisting force is of course going to happen with whatever brakes you used but of course the stronger the brakes the more twist. The wishbone is there to take care of that and I’m certain they would be up to the task, if not they can be reinforced.
jeepguy1948 is offline   Reply With Quote
Old 10-29-2022, 01:11 PM   #8
asapguy
asapguy's Avatar
I saw disk brakes installed on the front axle of a stock Model A tudor and it looked terrible.
asapguy is offline   Reply With Quote
Old 10-29-2022, 02:54 PM   #9
Kevin in NJ
Some basic science here.....
So Model A brakes properly rebuilt do a wonderful job stopping it from 65-70 MPH. The limiting factor is the tire contact patch on the pavement.
The best you can do force wise is keep the braking force just below where the wheel locks up. Once it locks up the braking force is greatly reduced. Factory brakes have no problem locking the wheels when they are rebuilt properly.
So the forces are same for factory brakes or disk brakes cause no matter what the conditions. The limit is the tire on the road.
So obviously if you go to later tires you will get more force, but that still is not really a problem because the axle is way tougher then braking force as the force of a pot hole at 30 MPH is likely way more.
The A does not need different brakes it needs properly rebuilt brakes. A properly rebuilt car running 60 MPH will do fine stopping with properly rebuilt brakes.
Doing brakes on the A is not cheap, easy or fast. It also requires special tools and like most of the A, Attention to details. I find most people cant do them right.
Kevin in NJ is offline   Reply With Quote
Old 10-29-2022, 03:31 PM   #10
nkaminar
nkaminar's Avatar
A few comments: Disk brakes are not available for a stock Model A. So going to disk brakes means changing out a lot more than just the brakes. Most Model A's are not driven hard enough to need disk brakes. Lots of people like to keep their car as tock as possible, or at least looking stock, so disk brakes are not for them.
The advantage of disk brakes is fade resistance. So if you are coming down Pikes Peak you can ride the brakes all the way down without having to worry about the brakes fading.
Regarding tires: If you want to keep the stock size wheels, the best you can do is go to radial tires, which grip the road better. The larger tires, I am thinking 16 inch wheels, are better on dry roads, but will have a greater tendency to hydroplane on flooded roads.
Old 10-29-2022, 06:45 PM   #11
Synchro909
Synchro909's Avatar
Thanks again
Disc brakes or drum, the twisting will be the same unless you use stickier tyres, then the sky is the limit but who wants to drive a hot rod???
When all is said and done, more is said than done. That's why we judge people on what they do, not what they say.
I sometimes wonder what happened to the people who asked me for directions.
If I am not in trouble, I've done something wrong.
Old 10-29-2022, 09:16 PM   #12
jeepguy1948
I want to drive a hot rod....
Old 10-29-2022, 09:41 PM   #13
Pete
I can sell you one. LOL
Old 10-29-2022, 10:20 PM   #14
burner31
burner31's Avatar
Trust the Frank
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 10-29-2022, 10:24 PM   #15
burner31
burner31's Avatar
I love my Model A, but like you, sometimes I like to drive a hot rod
And sometimes...it's hard to decide which one
Keith
Shawnee OK
'31 SW 160-B
Old 10-30-2022, 09:41 AM   #16
Patrick L.
Patrick L.'s Avatar
There are a lot of hot rods running around with disk brakes on straight axles. And they work just fine.
But, on a stock Model A ? That just ain't right ! If the brakes have been installed and adjusted correctly the brakes will lock up if wanted up to about 40 mph. I've had to do it a number of times.
Old 10-30-2022, 09:54 AM   #17
GeneBob
I did not complete my train of thought yesterday.
Kevin in NJ picked up my train of thought. Since the limit to the forces put into the axle is based on the traction of the tire on the road, it doesn't matter what type of brake you use to apply the stopping force. Many hot rods use disc brakes with modern tires on original or (worse for twist) 4" dropped axles. The only twist concern I have heard comes from using radius rods with tube axles.
NKaminar, there are disc brakes for stock model A's, sort of. They are hydraulic and, I think, require later model spindles but Mike Hoskins outside of KC, MO is putting together a disc brake kit for use with stock Model A wheels right now.
The advantage of the disc brakes is the higher performance, the disadvantages include the looks and the loss of originality.
To each his own. Jason, it is your car, build it the way you want to. Model A's are not an endangered species.
Old 10-30-2022, 11:21 AM   #18
goodcar
Spend your money on restoring brakes to stock instead of cobbling and cutting to go to hydraulic.
goodcar is offline   Reply With Quote
Old 10-30-2022, 12:12 PM   #19
Jim Brierley
It's not about locking up the wheels, it's about fading, and almost anything is an improvement over stock 'A' brakes. Come down Pikes Peak and you'll find out what it is like.
Old 10-30-2022, 02:04 PM   #20
Dan McEachern
James- if you're coming down Pikes Peak, why were you using your brakes!! Dan
Dan McEachern is offline   Reply With Quote
