#1 |
I am currently trying to get my top frame ready to install a new top. I have posted this question before but received no information. I have also contacted Ricky at Classic Wood but he couldn't help. So here is the situation. It looks like the wood section of the front bow (header?) has been replaced by a precious owner. My concern is that the size of this replacement header may not be correct and may be too wide creating too much "overhang" above the windshield which would make fitting the new top difficult. Can anyone help with the correct dimensions for the wood. I think the overall length is ok as the clamps fit to the stanchions ok. It is the vertical and horizontal measurements of the wood that I need. Any help would be appreciated.
#2 |
fundy, you helped me maybe this will help, my 31 roadster header is 49 7/16" long, center width is 2 1/4 wide and forgot to measure thickness , looks like 3/4, i can get it if you need. It tapers down to the ends not much but does taper to the radius.
kurt |
#3 |
Thanks Kurt. Is your car a Standard or Deluxe? I'll measure mine tomorrow and see how it compares.
#4 |
31 deluxe, i don't know but i would think the only difference would be the height of the windshield.
#5 |
Unfortunately, a completely different top structure as well. I don't think any of the top components are the same. For example, my front bow (header) is only 42" long (wood only) and the other 2 wood bows are straight vs the curved deluxe ones. Thanks for trying anyway.
#6 |
Total Records Found: 2 PART NUMBER Part Name PREFIX SUFFIX Notes EI Drawing Date 42055 TOP RIB #1 A OBSOLETE 3-2660 - 6/3/38 31-16695 1930-07-02 42055 TOP RIB #1 A 14611 1929-11-18 |
#7 |
Hello, as mentioned I don’t think anything will interchanges from a Deluxe to a Standard top , the Standard top for 30 31 is similar to the earlier 1928 29 , they are more of a steel formed tube design, not sure if pieces interchangeable between those tops . Maybe if someone with a 1928 29 roadster could help out .
#8 |
28-29 are made of the same design as 30-31 std
But dimension are different. Won’t interchange |
#9 |
Thanks everyone for your comments. reinforces my thoughts that the 30-31 Standard top is unique to that car. Maybe someone with one of these cars can do an actual measurement for me. Seems a lot of the Standards have been converted to Deluxe by restorers so someone with a Deluxe may also have the original standard top frame laying around that they can measure for me.
#10 |
Thanks Bob for the reference to the drawings. I spent a little while on the site but no luck with the particular bow/header that I am looking for. Very interesting site though
#11 |
Fundytides: I redid my ‘30 Std top several years ago and kept the original bows. They’re up in the garage loft. Will dig them out this aft, take some pics & measurements and post them for you. Stay tuned.
Sent from my iPhone using Tapatalk |
#12 | |
![]() Quote:
Dave. |
#13 |
Here you go. Apologies for the freehand sketch. These are from the uppermost bow in the attached photo. Hope this is what you need!
What part of NB are you from by the way? I was born in Moncton - more years ago than I care to ponder! Cheers! |
#14 | |
![]() Quote:
Dave |
#15 |
I have a 29 Roadster convertible that I put a new top on about 4 years ago. Mine has the two notches is the wood. They are for two support straps that go from front to back to help keep the top from sagging. Hope this helps.
#16 |
The trimmed sections on either side and the one in the middle are for attachment of the (3) top straps, per pics attached.
![]() Glen |
#17 |
#18 |
Hello again ,you tube had a video on from Lebaron Bonnie showing installation of top on a roadster, chiseling out slots in top bows for the straps, recessed into the wood so they don’t show as bulges on finished top , also make sure the bows have no high spots or irregular surfaces that will show up under the top.
