Old 10-22-2022, 10:52 AM   #1
Krylon32
Default Fenton Headers
What are the correct bolt lengths and sizes for my NOS Fenton headers? Don't want to get into the water jackets
Krylon32 is offline   Reply With Quote
Old 10-22-2022, 02:26 PM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Fenton Headers
(4 front) 7/16" 14 x 1-3/16 "
(8 ) 3/8" 16 x 1-1/4" center and rear
Stock bolts but you will have to determine length as the flange
on the Fenton headers may vary in thickness from stock.
Old 10-22-2022, 03:11 PM   #3
KiWinUS
KiWinUS's Avatar
Shouldn’t the left center lower bolt on originals be about an inch longer? I have 4 sets and that bolt is about 1 3/4 longer. I am away from home so can’t check exact lengths
Old 10-22-2022, 03:48 PM   #4
34PKUP
34PKUP's Avatar
For Fenton headers ??
34PKUP is offline   Reply With Quote
Old 10-22-2022, 05:02 PM   #5
KiWinUS
KiWinUS's Avatar
Yes original Fenton Headers. Can post pics when I get home from Moonshine Festival tomorrow.
Old 10-22-2022, 06:08 PM   #6
KiWinUS
KiWinUS's Avatar
https://www.fordbarn.com/forum/attac...0&d=1587224341
These are from an old post. These are mine. I now have 4 really nice sets one NOS. LOOKat the lower left center bolt. These have the Ford part number on them. Old and nice.
Old 10-23-2022, 02:29 AM   #7
51 MERC-CT
51 MERC-CT's Avatar
Suppose the long bolt would be correct if the OP indeed has that variation of header, otherwise he would have to determine which length/s are needed.
Old 10-23-2022, 07:19 AM   #8
A bones
A bones's Avatar
Perhaps Driskel can help.
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
Old 10-23-2022, 08:36 AM   #9
glennpm
glennpm's Avatar
- First clean all the exhaust manifold holes out.
- Using two long bolts, 3/8 and 7/16"; hand thread them in the block and measure the protrusion under the head or to the outside of the bolt head
- Deduct 1/8" to 1/4" from the insertion length
- add thicknesses of manifold flanges and any washers or lock washers if you plan on using them
- buy or custom cut the bolts to the dimensions you calculated
Old 10-23-2022, 08:46 AM   #10
CA Victoria
CA Victoria's Avatar
The manifold pictured looks like the speedway version of Fenton’s original header. The lower bolt in the center flange is longer.
File Type: jpg F1A49EAF-DE0D-4265-91F6-565308EC0F68.jpg (67.7 KB, 48 views)
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 10-23-2022, 09:49 AM   #11
KiWinUS
KiWinUS's Avatar
Open the picture in my post to see originals with longer bolt needed.
Old 10-23-2022, 12:01 PM   #12
tubman
tubman's Avatar
Looks like there may have been two types of original Fenton's, unless those are re-pops.
Old 10-23-2022, 12:34 PM   #13
Karl Wolf
Karl Wolf's Avatar
I used studs, and brass nuts...
Karl
Karl Wolf is offline   Reply With Quote
Old 10-23-2022, 12:42 PM   #14
KiWinUS
KiWinUS's Avatar
OR these are “THE ORIGINALS “
