10-03-2022, 11:51 AM | #1 |
40 coupe dual master cyl
Anyone here done the conversion from single to dual master cyl and what parts were used ? I see the adapter and 69-70 mustang drum to drum is the way to go. How did yours work out ?
thanks kurt |
10-03-2022, 11:55 AM | #2 |
Re: 40 coupe dual master cyl
Early 60's Cadillac had a drum/drum dual MC that used the SAME size tubing as Ford. I had a '34 with one in it. Operated from the center bellcrank and mounted on the right leg of the X member. 62/63 Cadillac. Newc
10-03-2022, 12:09 PM | #3 | |
I too have heard several positive reasons for using this early '60s Caddy M/C in an old Ford that still has original brakes and hydraulic lines. The bore diameters appropriately match what is necessary for the old brakes to 'feel' right, as well as the easy adaptation/match with original Ford brake tubing diameter. Coop . |
10-03-2022, 05:03 PM | #4 |
I put a '69 Mustang MC in my '40 coupe. Using the adapter on the frame mount, the push rod needs to be lengthened by the thickness of the adapter. Also, I had to section the cover (sliced , then brazed) to clear the floorboard. Otherwise it operates very well. If I did another I would use the Corvette MC......easier installation.
EDIT: You will need to make up some brake line sections for the split in the system....no big deal though. Last edited by hotrodart; 10-03-2022 at 05:09 PM. |
10-03-2022, 05:41 PM | #5 |
Stuff like this needs to be put on the HAMB. Just leave them the way Henry built them.
10-03-2022, 11:28 PM | #6 | |
Coop . |
10-04-2022, 07:16 AM | #7 |
Thanks Coopman i figured i would just keep my mouth shut.
10-04-2022, 08:06 AM | #8 | |
So I guess this means no turn signals, second tail light, seat belts, brake floaters, safety glass, etc?
Making the simple complicated for over 30 years. |
10-04-2022, 08:30 AM | #9 |
How about taking the new easy approach.
10-04-2022, 09:02 AM | #10 |
THANKS, U BUCK, i looked all over for something like that going to order one.
thanks kurt |
10-04-2022, 12:33 PM | #11 |
Caution the MC pictured will have the brake lines coming out towards the drivers side . Check your exhaust clearance to brake lines .
Stretch |
10-04-2022, 02:32 PM | #12 | |
Yes, I have hydraulic brakes and turn signals on Apatchy. He also had dual horns which conceal the front turn signal lights, and dual tail lights so as to indicate the direction I would be turning. As the name of my truck implies, it is built with patches. Your acutely discerning mind should have been able to instantly comprehend that. Sorry if I confused you.
