Old 09-27-2022, 06:43 PM   #1
McMimmcs
McMimmcs's Avatar
Default Who has the best replacement fan ?
Recently had a blade break off. Thanks in advance. Wayne
McMimmcs is offline   Reply With Quote
Old 09-27-2022, 08:17 PM   #2
Gene F
Gene F's Avatar
Default Re: Who has the best replacement fan ?
I have the 8 blade plastic one that Snyders sells. Takes a bit of fitting to get it on without it trouching the hosuing after you start the engine, but I like it. I drive my car not just look at it, so it was a good choice for me. I had a 4 blade, but took it off. I have a 2 blade, but have never used it.
Gene F is offline   Reply With Quote
Old 09-27-2022, 09:27 PM   #3
chrs1961815
chrs1961815's Avatar
Aluminum 2 blade fan is the only way to go if you drive the car.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 09-28-2022, 09:56 AM   #4
JKY
Agree.
JKY is offline   Reply With Quote
Old 09-28-2022, 11:23 AM   #5
Conaway2
Conaway2's Avatar
I have installed aluminum 2-blade fans on both of my cars. Bought them. From Brattons and neither needed any modification to fit without rubbing.
Jim
Conaway2 is offline   Reply With Quote
Old 09-28-2022, 01:33 PM   #6
gdmn852
gdmn852's Avatar
Hello, have the aluminum 2 blade from Snyders,being a casting, it is thicker around the pulley area and sometimes the water pump will need ground down for clearance. This might be dependent on the reproduction water pumps, if the machining isn’t centered on the cast pump.
gdmn852 is offline   Reply With Quote
Old 09-28-2022, 02:10 PM   #7
Mulletwagon
Mulletwagon's Avatar
Same here. Some minor filing on the pump snout to take down some small imperfections and it was good to go and performing great.
Mulletwagon is offline   Reply With Quote
Old 09-28-2022, 04:56 PM   #8
Synchro909
Synchro909's Avatar
My Tourer is a DRIVER and I take a different view and run one of those plastic fans. I figure it's less likely to break and if it does, the light weight piece of plastic that comes off won't do much (if any) damage. On my less driven car, I have the aluminium fan.
I sometimes wonder what happened to the people who asked me for directions.
Even at my age, I still like to look at a young, attractive woman but I can't really remember why.
Old 09-29-2022, 06:05 AM   #9
chrs1961815
I mean I have yet to hear of an aluminum fan breaking since it is a one piece casting that is pretty thick and light.
Old 09-29-2022, 01:52 PM   #10
Werner
Werner's Avatar
I mounted the aluminum propeller. It works well and with less noise. The original sheet iron part had cracks on the hub.
Beste Gruesse aus Deutschland,
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 09-29-2022, 06:06 PM   #11
Bob-A
Bob-A's Avatar
Wink Re: Who has the best replacement fan ?
I've got one of early repo aluminum 2-blade fans. I got it off of greed-Bay.
After receiving it and checking it out I could tell by sight alone that the design was flawed. Plus I'm sure it was unbalanced. Now just a peg board ornament.
Bob-A
Bob-A is offline   Reply With Quote
Old 09-29-2022, 07:07 PM   #12
McMimmcs
McMimmcs's Avatar
I ordered a two blade aluminum from Snyder’s. Thank you everyone! Wayne
Old 10-05-2022, 01:16 PM   #13
81ls1camaro
Bob-A
Can you give us more details on what was flawed about it? You can probably check it for balance like you do lawn mower blades and hang it on a nail. Just a idea anyway.
81ls1camaro is offline   Reply With Quote
